20 Most Recent
Sony KV-27S65 27" TV Questions & Answers
The Screen goes blank intermittently, but sound stays on.
Check all the solder terminals at the CRT base board. Check for any loose contact there. Unplug and re plug all the plugged socket once.
Visit the site named 'Electro-help' for
more details. Click this link. View it in
"Timeslide" option, which can be selected from the drop down box
menu by the [Sidebar] tag, at the top left corner of the display
window. It will make search easy. There
are more than 1000 posts to different brand TVs now. Pull up older posts there.
Sony KV-27S65 27" Television suddenly has very low volume
that problem is very common on a sony tv,the sound IF and video IF of your tv is bad..video and sound IF is located near the tuner section of your tv.some sony model,the IF section and TUNER section are packed in one enclosure. it your tv sound IF is packed together with the tuner,then replace the tuner with a new one.some are packed separately so you need to replace just the IF module only..you can also try to adjust the IF by using a plastic smsll screw driver adjust the IF clock wise or counter clock wise untill you achive a good reception do it with the tv power is on..be carefull with the high voltage...
tnx and please rate my help..
Panasonic color tv model ct-13r38sg 13"
verticle amplifier is not working on your tv
take it to a shop if you dont know.
verticle IC BE CHECKED.
AND ELETROLITIC CAPACITOR feeding verticle scan coil.
Panasonic tv help
my tv screen just turned brown. sound and everything else works fine?????
Panosonic HD tv
Panasonic color tv model # ct-13r38sg
The problem here is that the vertical IC either has bad connections or is defective. Look for a small flat IC with about 11 pins attached to a heat sink. It will be marked LA7837 or something similar. Try resoldering the pins on the IC first. If that fails to resolve the problem replace the IC.
Keep us posted.
Dan
Picture gone
If you put the back of your hand to the front of the picture screen does it make the hair stand out like static? If not there is no high voltage..Does the audio come from the receiver to the tv or to a suround sound system? My first suggestion is to disconnect the tv from every thing. Plug in an exterior antenna/rabbit ears or just a paper clip into the cable connector and see if you get any local channels. If you have none available, connect to a known good dvd or vcr and see if it works correctly. If so then something has died in the receiver modulator. It might then be possible to use only the audio/video outputs on the receiver to get everything working, however the problem could be deaper in the receiver and not able to be bypassed.....Let me know what you have tried and if anything works. etc.....
Low audio output all of a sudden
I had a similar problem and opened the box and blew out a ton of dust. Still don't know what the problem was, but the sound came back.
Age
I am using sony 2062 model since year 1982
& most of my friends are using 2032 since that time.
of course we have modified it to increase channels.
but in my opinion it is like gold.
excellent colour & picture.
so i can say it has minimum life of 20 years with good light.
hope this will help.
Your assistance
The Sony part number for these diodes is 8-719-108-12 and yes they are 9.1 volt zener diodes @ 1 watt. I have the service manual for this set if you need it put can only send a large file like this trough a proggy called pand, so if you go to pando.com and get the proggy and leave youe e-mail addy I will send you a copy of this service manual. Good Luck
Part help
the vertical o/p generic number stamped on the fron of the ic is "TDA8172" the sony part number is "8-759-980-58".
good luck
I NEED CODES FOR MY NEWSTAR NTR-B28Z FOR MY SONY TV
ChatGPT 3.5
User
I need code for newstar ntr b28z for my Sony tv
ChatGPT
Unfortunately, I can't provide specific code for your Sony TV remote without knowing the exact model number. However, you can usually find the code in the user manual of your Sony TV or by contacting Sony customer support. Alternatively, you can try using the auto-search feature on your newstar ntr b28z remote to find the correct code for your Sony TV.
User
ChatGPT
To find the code for your Sony TV using the Newstar NTR B28Z remote, you can try these general steps:
Turn on your Sony TV.
Press and hold the "TV" button on your Newstar remote until it blinks twice.
Enter the code for Sony TVs. Some common Sony TV codes are: 0000, 0011, 0080, 0111, 1234. If none of these work, you can proceed to the next step.
Press the "Power" button on the Newstar remote. If the TV turns off, the code is correct. If not, try a different code.
Once you've found the correct code, press the "TV" button again to lock it in.
If none of the provided codes work, you might need to consult the manual of your Newstar remote or contact their customer support for assistance.
