20 Most Recent
Symbol Spectrum24 4131 Access Point (AP-4131-1050-Z2-WW) 802.11b Questions & Answers
Reset Access point Cisco 1020
If your current controller can't see the AP, then the 1020 can only be reset through the Controller it was originally configured with. It doesn't have a console port, so you have to connect it to the old controller and run "clear lwapp private-config"
3/26/2014 9:30:45 PM •
Symbol...
Answered
on Mar 26, 2014
Hi! I have a number
What do you need to know / what do you already know ? This is a large question.
1. Are all your access points configured
2. For your captive portal you could use
MikroTik software. There is a large community based on the software and step by step instructions to setup a captive portal.
3/1/2011 3:38:03 PM •
Symbol...
Answered
on Mar 01, 2011
I want to bridge two AP's but they don't find each
the issue is if your using bridge mode then you have to use differnt IP for both Router
if your main router using this IP like 192.168.1.1
second router sute use folowing IP 192.168.2.1
it will work changing IP's
4/20/2010 2:31:38 PM •
Symbol...
Answered
on Apr 20, 2010
My symbol 4131 and pdt4686
You can connect a console cable to the console port and login using a freeware terminal emulation app such as Tera Term Pro. The default password is: Symbol
PDF manual:
http://www.guardit.cn/UploadFiles/symbol_ap4131_engmanual.pdf
Use chapter 5 for instructions on creating a new authentication key that will match your computer setting.
7/1/2009 9:30:21 PM •
Symbol...
Answered
on Jul 01, 2009
Symbol 6846 not associating with
Hello there, I believe you have a chat going as well? I will be glad to help you, please let me know if you want to do it this way or via chat... Do you have google chat or anything that we could maybe use? It will be pretty difficult to diagnose and fix in a back and forth email format.
7/1/2009 9:19:37 PM •
Symbol...
Answered
on Jul 01, 2009
My Kenwood 1 ton inverter ac outer not starting some times start show compressor symbol and then turn off and not start again doesn't show any error please guide
If your Kenwood 1 ton inverter AC is having trouble starting and sometimes shows the compressor symbol before turning off, there may be a few things you can check to diagnose the issue.
- Power Supply: Check that the AC is receiving proper power supply, and the circuit breaker is not tripped. Sometimes, due to voltage fluctuation, the compressor may not start.
- Dirty Air Filters: Check the air filters and clean them if they are dirty. Dirty air filters can reduce the airflow and cause the AC to malfunction.
- Faulty Thermostat: If the thermostat is faulty, it may not be able to detect the temperature properly and cause the compressor to not start. You can check this by setting the temperature to a lower level and see if the AC starts.
- Low Refrigerant Level: Check the refrigerant level in the AC. Low refrigerant levels can cause the compressor to not start.
If none of these steps solve the issue, it may be best to contact a professional AC technician to diagnose and repair the issue.
How to type degree symbol on mac
There are a few different ways to type the degree
- Use the keyboard shortcut: Press and hold the Option key, then press the letter K on your keyboard. This will insert the degree symbol.
- Use the character viewer:
- Go to the Edit menu and select Emoji & Symbols.
- In the search field, type "degree".
- Double-click the degree symbol to insert it into your document.
- Use the ASCII code:
- Press and hold the Option key and the Shift key.
- Press the number 8 on the numeric keypad. This will insert the degree symbol.
I hope this helps! Let me know if you have any other questions.
Videocon ac remote not working
Please reach out to videocon on twitter to help take care of this issue: @VideoconIndia . You can tweet their handle with the issue included.
You can also call 1800 1370 444 to reach them. I believe that is a number based in India. Thank you.
