20 Most Recent
Sony KV-XR29M50 TV Questions & Answers
Power supply
To buy a new power supply, contact the authorized service center for Sony. If you wish to get it troubleshoot, check the site linked here. If you're sound in electronics, you can follow.
Pull up previous posts by its left sidebar, or type in the
brand name and model number to of your set, to its search box, and press '
Enter'
or view it in
Mosaic / Timeslide option.
KV-XR29M50 WITHIN FEW SECONDS +135V DROP
B+ of 135V is OK.here is a guide for you to have:
Flyback Transformer
If the Q511 is OK, then solder it back.Plugged the unit in , without the C Board connected to the CRT.If it powers On, completely, you just found the cause.If it has the same symptoms troubleshoot on the other Board.
Color is over red
The color of the Television is compose three color,the Red,Green and Blue.First thing to do is try to adjust the color adjustment.Adjust and balance the color.
Comes on after 30 40minutes
Hello
Its picture tube base socket has damaged. Picture tube base socket is one diretly soldered to the base card, which in turn pluged onto the picture tube neck. Its focus control pin will usually get damaged, and this type of fault you describes here will occur. The time taken to clear up picture will vary according to atmosphereic humidty.
You can replace the base card. Unplug the base card from the picture tube base card [do it ver cauciously; not to shake it sideways or up-down - just pull it straight backwards; you may have to apply a little pressure to detach it from the picture tube neck]; resolder it out from the card and go for a new one. Replacing it will solve your TVs problem. OK.
I NEED CODES FOR MY NEWSTAR NTR-B28Z FOR MY SONY TV
ChatGPT 3.5
User
I need code for newstar ntr b28z for my Sony tv
ChatGPT
Unfortunately, I can't provide specific code for your Sony TV remote without knowing the exact model number. However, you can usually find the code in the user manual of your Sony TV or by contacting Sony customer support. Alternatively, you can try using the auto-search feature on your newstar ntr b28z remote to find the correct code for your Sony TV.
User
ChatGPT
To find the code for your Sony TV using the Newstar NTR B28Z remote, you can try these general steps:
Turn on your Sony TV.
Press and hold the "TV" button on your Newstar remote until it blinks twice.
Enter the code for Sony TVs. Some common Sony TV codes are: 0000, 0011, 0080, 0111, 1234. If none of these work, you can proceed to the next step.
Press the "Power" button on the Newstar remote. If the TV turns off, the code is correct. If not, try a different code.
Once you've found the correct code, press the "TV" button again to lock it in.
If none of the provided codes work, you might need to consult the manual of your Newstar remote or contact their customer support for assistance.
