20 Most Recent
Sony KV-27FS13 27" TV Questions & Answers
MY WEGA SONY KV-27FS13 TV
Hello, hopefully you can help me. I just brought a used sony wega kv-27fs13 27 flat-screen tv. But when I put the cable wire in the TV it says No Signal. Do you know what the problem could be?
I HAVE A SONY WEGA
I'm sorry to inform you that the TV cannot be used directly with PAL color system. However, you can use a PAL to NTSC converter to resolve the issue. You can get the PAL to NTSC converter from any local Electronics Shop.
Thanks for understanding. Please let me know if you require any clarifications.
My sony kv-27fs13 has a problem .. the standby
Hi there
In sony tv`s the 4 blink code(sony error codes)usually indicates a vertical deflection problem.
Your vertical output i.c and/or related components are probably faulty and need to be replaced.
If you feel that your up to repairing it let me know and i`ll see what i can do to help.
Merry Christmas
Sony KV-27FS13 27
this sounds like 60hz or 120hz a/c ripple distortion. if taping tv corrects temporarily, ther must be poor solder on main a/c ripple filter. very large usually blue capacitor near power cord input on pcb. do not short positve and negative legs together as you could be shocked(even after tv is unplugged) and also cause more damage to tv. these filters can store electrical charges for days, even if unplugged the whole time. careful! mch
No picture No sound
This is an indication that the sweep power supply did not give the turn on pulse from the SMPS, thats the main power supply. If you know how to use a multimeter I will send you the instructions to troubleshoot this supply. Or you may need to trouble shoot the sweep supply as well. If you have no electronic or solid state repair experience, Please stay safe and call in a trained tech to assist you with this repair. Good Luck
PS please rate this thread
Sony Trinitron KV-27FS13
Good day.
Maybe there is a problem with eigther the vertical or horizontal circuitry of your unit. blinking lights indicate a problem associated with your flyback not being able to oscillate and distribute the supply for the tuner, audio, vertical...etc..
That is an internal problem pls refer to a qualified technician.
chris
No sound and picture or video
please help !!!! is it an expensive fix ?
yes it is too expensive to fix it
better to buy new one.
as even you fix it , it will always give you problem.
good luck
Buttons on top of TV don't work
Try to press them a bit harder, sometimes they become oxidize due to non use. If there was one that is stuck, you will not get any of them to work even the power button.
Try using the remote control.
Good Luck.
Digital
Good day,
Yes, it has a digital tuner. It is functioning based on the command set by the buttons or signal/command from remocon.
chris
