20 Most Recent
Sony KV-27FS12 27" TV Questions & Answers
Bakit seksi ung screen?
What do you mean by this Bakit seksi ung screen. Send details of the fault. I can't understand it.
Menu won't show.
sounds actually like it has had weather damage, sometimes water can get into a place it shouldnt on a tv, not shorting it out, but instead messing up in your case the numbers or menu screen, so i'd say it is best to take it to tyour nearest recycler, hope this helps.......jason
Weird sound coming from the inside
TV needs some kind of service and dust inside to be removed.
Regarding sparks sound, it can be leakage of high voltage of Fly-back Transformer. Qualified tv technician can check and repair it as high voltage risk is involved here.
Thank you.
Flyback serial?
The Sony part number for the flyback transformer is:
1-453-310-11
My Screen doesn't work
You can not find where the noise is coming but a service technician will know where to look and what to check.Get an estimate.
MY TV SONY KV27FS12 PICTURE PROBLEME
Hey Rolly no problem man as if we can help ya your not taking up our time as we answer when we can. Ok theres is still a small cap somewhere by the drive ic or they call it the jungle ic. If you have a schematic scan the vert part and I will assist you the best i know how.
I NEED CODES FOR MY NEWSTAR NTR-B28Z FOR MY SONY TV
ChatGPT 3.5
User
I need code for newstar ntr b28z for my Sony tv
ChatGPT
Unfortunately, I can't provide specific code for your Sony TV remote without knowing the exact model number. However, you can usually find the code in the user manual of your Sony TV or by contacting Sony customer support. Alternatively, you can try using the auto-search feature on your newstar ntr b28z remote to find the correct code for your Sony TV.
User
ChatGPT
To find the code for your Sony TV using the Newstar NTR B28Z remote, you can try these general steps:
Turn on your Sony TV.
Press and hold the "TV" button on your Newstar remote until it blinks twice.
Enter the code for Sony TVs. Some common Sony TV codes are: 0000, 0011, 0080, 0111, 1234. If none of these work, you can proceed to the next step.
Press the "Power" button on the Newstar remote. If the TV turns off, the code is correct. If not, try a different code.
Once you've found the correct code, press the "TV" button again to lock it in.
If none of the provided codes work, you might need to consult the manual of your Newstar remote or contact their customer support for assistance.
