20 Most Recent
Sony FD Trinitron WEGA KV-20FV300 20" TV Questions & Answers
Tv won't change from chanel to chanel
Do a hard reset to this set and check first. To make it hard reset, unplug the set from AC mains wall socket, and re-plug it back after 10 minutes or so.If this do not help you, check and replace its main system memory IC.
9/30/2012 3:00:38 AM •
Sony FD...
Answered
on Sep 30, 2012
Sony tv kv-20fv 300 power light just blinks
Try connecting the TV directly to a different wall outlet and check. If the issue persists, try power resetting the TV. Turn Off the TV and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation. If the issue persists, then the TV requires service.
7/27/2010 10:59:52 AM •
Sony FD...
Answered
on Jul 27, 2010
I have connected a Toshiba
SCART cable just transmits the signal thats on your tv's tuner to your recorder. In other words, you can record only what you are watching. If you want to get around this, then connect the cable or satellite signal source directly to the recorder, and then connect a cable from the video out of the recorder to the video in of your tv. That way you can watch one channel and record another.
Let me know if you need more help,
Sai.
1/2/2010 5:37:49 PM •
Sony FD...
Answered
on Jan 02, 2010
Cant change channels?
What is your antenna source? Cable or antenna? Try keying in a certain channel on your remote. see if you get that channel. Tv will not auto program if you do not have channel source coming in to antenna input.
11/3/2009 4:01:10 AM •
Sony FD...
Answered
on Nov 03, 2009
Volume goes up on its own!
Hi, We are Zener
we suggest you reset the tv with a secuence of service
that is exclusive with the remote,
is pressing the buttons(display channel 5 volume + power)
the tv turn on, appears parameters on the screen, only press
8 and enter, all your set get as you buy it.
Note: change any parameter, because you are getting in the tlevision`s memory.
Zener, from Mexico
Bye
7/28/2008 12:27:58 AM •
Sony FD...
Answered
on Jul 28, 2008
TV automatically switches to channel 666.
Sounds like a bit of a devil(lol),could be interferance from a device causing this problem,have you got a flourecent light in the room,this is known to interfere with the tv's remote sensor,also try taking the batteries out of the remote???
Failing this it could be a fault in the tv,an i.c. has become corrupted and will need software to be re-installed but this is the worst case scinario.
4/20/2008 7:44:07 PM •
Sony FD...
Answered
on Apr 20, 2008
Volume gone mad
Is there a ceiling fan in the same room? Under the right conditions, light reflecting off the whirling blades hits the TVs sensor at just the right frequency, causing mysterious things like this.
Try covering the infrared sensor on the TV (it should be behind a red transparent piece of plastic somewhere in the front. If this keeps it from "going mad", then something in the room is to blame. If it still does it even when the sensor is covered, then it is the TV.
Good luck, and let us know what you find!
3/12/2008 3:38:00 AM •
Sony FD...
Answered
on Mar 12, 2008
