20 Most Recent
Sony KV-32FS12 32" TV Questions & Answers
What can i do if
This T.V. doesn't use a lamp. If you're referring to the picture tube, there is no fixing this other than making slim adjustments on the knobs on the flyback. Don't tweak it too much or it will cause retrace lines. However, in most cases a bad picture tube means its time for a new T.V.
My TV's picture constantly turns
I have not repaired this particular TV. But my guess is you have some bad solder grounds on this aging TV. I would certainly inspect all your grounds on the CRT board and the main board. I would take a look at the color crystal. This crystal is a small silver box with two legs and may be next to the jungle IC. This two legged crystal in some cases have had bad grounds. Try this, and see what happens. Thanks for asking and show a few hands of support!
Sony KV-32FS12. Buttons on the TV don't work, the
Hello
Your TVs front control buttons are inoperative except menu button. There are microswiches fitted inside the main board of your tv from which shafts ar extented towars the front of the cabin where you press to access the functions. Replace all the micro swiches inside at onetime. It won't cost more. Micro swiches as they have said is mini swiches, which can get damaged easly with high pressure thumb or impact put on it.
Dim picture
Turn the contrast setting all the way up.The brightness setting about half.The rest set half too.The tv picture should look fine.
After the tv has been off for only a few minutes
Hmm, you have 2 possibilities that I can think of. First, if the picture color and brightness seem relatively normal, I would replace the CRT driver on the C board. This is attached to the back of the CRT via the pin socket. Second, if you notice a darker picture or faded color during the cycling period... things are not as rosy. This is a good indicator of a High GR (gas ratio) condition. Basically, your CRT is leaking.
The tv picture would flash on and off, but the
your tv has a cold solder.this means that connections in the video circuit loose heated have a tech look at your tv and resolder the video circuit.that should correct your problem.if it dont then your tv has a major problem.then it is time to replace the video ic.good luck.
Sony KV-32FS12 32
It weighs 165 pounds. Also, Width: 31.5 inches. Height: 27.88 inches. Depth: 23 inches.
Sony kv-32sf12 -will not power "ON
Try the 60 seconds unplugging of wall plug in your outlet. Or check your line if this have surge protector. Temporary plug your unit to wall outlet directly. Just check if it still within voltage operating range.
The problem I am having is that my 32' Sony Wega
Picture alignments made in servive menu.
pwr off + display + 5 + (+vol) + pwr on
You must do all within 1 second.
1&4 move thru settings, 6&3 chg value,
muting & enter saves chgs.
Your code access could differ.
In the menu note down all existing settings.
Make small adjustments and watch what happens if not in right direction reset that particular option to original value before you changed. In those menus you can bend, shift hor. and vert., etc.
But be warned only slight adjustments and write down start values before experimenting. Or you can get in to serious trouble.
Good secret service menues keep an access counter for manufacturer/dealer to see how many times it was used.
Sony KV-32FS12 Component Video 4 Has A Wavy Picture
sounds to me like the differnence between watchiing in progressive and interlace. these older tube tv's are not capable of displaying a progressive scanned image. like the first dvd players. check your video out settings on your ipod to make sure its an interlace output.
TV won't turn on
Hello Bob61E,
life safty should be 1st priorty before opening of TV set ;)
if you are skilled or qualifeid, then go-ahead and
if its Sony TV, you will see stand-by light blinking while tv try to power up. let me know how many time this light blinks.
Tv is not turning on
The set is in shut down there is nothing an average joe can fix. But if you have any experience check convergence chips and resistors also check for bad PC connections Good luck
A 4 year old, a squirt gun, and my Sony TV!
Stop!Clean area around all tactil switches and
replace any that are defective.One or more of your function select switches up front is shorted---sending a continuous signal to the micro IC.Good,used switches are fine,but must
have same physical parameters as originals.
