20 Most Recent
Sony FD Trinitron WEGA KV-34XBR910 34" TV Questions & Answers
Sony kv-34xbr910 wont turn on
I have sony 34 XBR Tube trinitron HD TV. We are not using the TV because it keep giving us 6 blinks and does not turn on
10/18/2021 11:47:48 PM •
Sony FD...
Answered
on Oct 18, 2021
The source indicator stays on
Please press Info/ Display button on TV Remote so on-screen display that shows source will disappear.
Please note that only Sony TV Remote will work to close/ disappear on-screen display. Universal remote may not have that "Info or Display" button for that.
Hope this will help.
Thanks.
5/10/2011 11:49:13 PM •
Sony FD...
Answered
on May 10, 2011
The TV will not turn on. It blinks in standby for
6 blinks = No Horizontal (H STOP), no raster, goes to the blinking self diagnosis
function immediately. Check C515 & 516 and the jungle IC, IC206 (or similar component references for your model) and replace flyback transformer if required.
Generally, whenever horizontal OCP (over current protection) occurs, the primary cause is usually the flyback transformer (these short circuit/burn out), the horizontal output transistor(s) and the tuning capacitors in the transistor(s) collector circuit must all be replaced together. It is also a good idea to check the ABL (or beam limiter) circuit as components may have been compromised in it due to the failing flyback.
You could take it to a service centre and obtain a quote for estimated repair costs, then you can decide afterwards if it is worth repairing or not. It may not be economical and/or expensive.
3/3/2011 12:24:46 PM •
Sony FD...
Answered
on Mar 03, 2011
TV won't stay on. Standby light flashes 5-10
Hello
Blinking of standby light in Sony sets are fault indication. You just count the exact number of blinks occur at on instance, say, after you switch On and OFF by its front panel power switch, not by remote control hanset. Just count it atleast 4 times, count it keenly and inform it to me, and let me reach to the nearest falult point; or sometimes to the exact point. OK.
12/6/2010 7:54:55 AM •
Sony FD...
Answered
on Dec 06, 2010
Tv try to turn on as soonest i am pluging it to
Yes, its normal as TV remember its last status like channel number/ AV input, volume level, video settings etc in its memory. If you put TV in standby and then unplug it, TV will turn on in standby mode after replugging back in.
Thanks.
9/22/2009 11:11:24 PM •
Sony FD...
Answered
on Sep 22, 2009
Tv doesn't respond to commands
Check the battery if its still good. if not replace with new one. if its still good, open the remote and inspect for loose connection. resolder if necessary. check also for possible crack pcb. good luck!
2/22/2007 9:46:28 AM •
Sony FD...
Answered
on Feb 22, 2007
I NEED CODES FOR MY NEWSTAR NTR-B28Z FOR MY SONY TV
ChatGPT 3.5
User
I need code for newstar ntr b28z for my Sony tv
ChatGPT
Unfortunately, I can't provide specific code for your Sony TV remote without knowing the exact model number. However, you can usually find the code in the user manual of your Sony TV or by contacting Sony customer support. Alternatively, you can try using the auto-search feature on your newstar ntr b28z remote to find the correct code for your Sony TV.
User
ChatGPT
To find the code for your Sony TV using the Newstar NTR B28Z remote, you can try these general steps:
Turn on your Sony TV.
Press and hold the "TV" button on your Newstar remote until it blinks twice.
Enter the code for Sony TVs. Some common Sony TV codes are: 0000, 0011, 0080, 0111, 1234. If none of these work, you can proceed to the next step.
Press the "Power" button on the Newstar remote. If the TV turns off, the code is correct. If not, try a different code.
Once you've found the correct code, press the "TV" button again to lock it in.
If none of the provided codes work, you might need to consult the manual of your Newstar remote or contact their customer support for assistance.
