20 Most Recent Sony FD Trinitron WEGA KV-27FS120 27" TV Questions & Answers
The service manual instructions to get into service mode is by turning the main power switch on the set. Then press the power button of the remote commander twice.
Sony FD... | Answered on Jan 21, 2018
Use the tilt adjustment in the menu system or if that doesn't go far enough, move the metallic object, (loudspeaker etc) further away from the screen.
Sony FD... | Answered on Jul 26, 2017
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/ Unlock procedure and to override the password lock to many popular brand TVs are given.
Sony FD... | Answered on Jan 07, 2015
Four blinks - No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted. Check IC1509, Q1505.
If you wish to get more details, check the site linked here.
Sony FD... | Answered on Nov 29, 2013
stop trying!!
let it dry out for a few days
if it still doesnt work you could try opening up tv and try replacing fuse inside
if it was just plain water it will be ok once it dries out
if replacing fuse didnt work power supply might need to be repaired or replaced
good luck!
Sony FD... | Answered on Jun 17, 2013
Check this link to download the user manual to this set. It has all details.
Sony FD... | Answered on Apr 12, 2013
If you wish to get more details, check this site. Pull up older posts there. Check the site with patience, as it has over 2200 posts now. All are related to electronic equipment repair help. Blinking codes to Sony TVs are given in detail.
Sony FD... | Answered on Apr 04, 2013
How many times it flashes at one time switch ON? Count it. These flashes are fault indications, called blinking codes. If you wish to get more details, check this site. Pull up older posts there. Check the site with patience, as it has over 2200 posts now. All are related to electronic equipment repair help.
Blinking codes and details to many model Sony TVs are given.
What is the problem you faces when connecting this TV with LG Blu-Ray player?
Sony FD... | Answered on Jan 21, 2013
The main power regulator section to your TV is faulty. Check the capacitors there for any damage.
Sony FD... | Answered on Dec 30, 2012
Check its main power regulator circuit section for any loose solder terminals. Re-solder all suspected solder terminals by applying a little more fresh solder.
Sony FD... | Answered on Nov 02, 2012
Contact the nearest authorized service center for Sony. This number of FBT is not in the open electronic spare part market now.
Sony FD... | Answered on Oct 15, 2012
Main chroma video jungle IC fault
Sony FD... | Answered on Sep 01, 2012
Sony FD Trinitron WEGA KV-27FS120 27" TV Logo
90 questions posted
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Televison & Video
Most Popular Question
tv least
  • Televison & Video
