20 Most Recent
Sony FD Trinitron WEGA KV-30HS420 30" TV Questions & Answers
Power supply
Check your board on power supply if you can find broken tracks.I might cause the problem
8/6/2017 1:30:05 PM •
Sony FD...
Answered
on Aug 06, 2017
Standby light flashes constantly without a pause. What is the problem?
Check and replace its main system control memory IC. It is not working properly. Check and replace damaged component/s at it main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "
Mosaic" or "
Magazine" will make surf easy. Surf the site with patience. Pull up older posts.
Do a search by type in the brand name of your device at its search box.
It will be best to replace the power supply regulator board as card basis.
5/25/2014 6:57:36 PM •
Sony FD...
Answered
on May 25, 2014
Standby light blinks 7 times on my kv30hs420 is it worth the repair
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating, to many popular brand TVs and other devices. Viewing it in "
Mosaic" will make surf easy.
Blinking codes details to many popular brand TVs are given.
Gopakumar Gopalan Google
3/10/2014 1:44:04 PM •
Sony FD...
Answered
on Mar 10, 2014
Sony Wega KV-30HS420 input problem
Just reset the TV to its factory settings and check. To do this you have to enter its service mode option. How to enter the service mode option is described in one among the posts at the site linked here.
But, before doing this reset, just connect the HDMI cable to the TV, and input an HDMI signal to it. If there is no input signal, the set will display as 'no input'. Check this first. If you wish to get further assistance from me, come over by FiXya comment.
2/17/2014 4:41:20 PM •
Sony FD...
Answered
on Feb 17, 2014
Sony FD Trinitron WEGA TV
Main board fault. IIC Bus line has a short. Continious blinks of standby light denotes this. These are called blinking codes.If you wish to get more details, surf the following
link. There are over two thousand and
four hundred posts. All are related to
television and other domestic electronic equipment service help. You can get a solution there. More than Nine Lakh viewers cannot be wrong.
5/6/2013 4:23:27 PM •
Sony FD...
Answered
on May 06, 2013
No tv red blinking lights
Blinking of standby light are fault indications. How many times the standby light blinks at a time. Count it, and inform me.
11/30/2012 3:24:35 PM •
Sony FD...
Answered
on Nov 30, 2012
How do i set up without cable converter box
Cable direct to coax fitting on rear of set, in menu set to CATV/cable, and auto program---any channels it misses or you do not want you can in same menu manually add or delete one at a time with the sets remote.
5/20/2012 2:20:45 PM •
Sony FD...
Answered
on May 20, 2012
we have a
There is a power supply fault causing the EHT to rise above 33KV.
High voltage
shutdown. The high voltage has exceeded 33k and the unit goes
immediately into safety shutdown. Check power supply regulation and
horizontal circuits.
Hope that points the engineer in the right direction.
8/16/2011 3:52:43 AM •
Sony FD...
Answered
on Aug 16, 2011
