20 Most Recent Sony WEGA KDL-32XBR950 32 in. LCD HDTV Questions & Answers
4answers
Sony wega engine LCD model; ldm-3210
If the Standby light is blinking at the front panel of the TV, it seems that there is an internal malfunction occurred in the TV.
I will forward a link to a page where you can get more information and troubleshooting steps for this issue.
http://www.kb.sony.com/selfservice/microsites/search.do?cmd=displayKC&docType=kc&externalId=C399467
Please perform the steps provided on the page. If the issue still persists then service of the TV is required.
4/14/2019 10:46:05 PM • Sony WEGA... • Answered on Apr 14, 2019
LCD Screen is showing degradation
One of my EDTVs has the same issue, though on a much smaller scale (it doesn't degrade the picture at all; it's only noticeable when the top of the screen is black, and it doesn't go down very far). Online reviews of the TV showed me it does have this problem commonly, so yours may too. It must be something you need to get it serviced for.
1/30/2018 10:55:52 PM • Sony WEGA... • Answered on Jan 30, 2018
My sony wega wont turn on and keeps flashing power light
Flashing of standby lights to Sony TVs are fault indications. Count the number of blinks occurs at one time after switch ON, and count it carefully. Check this link to know more about the blinking codes to Sony Brand TVs. You can get details there. You have't provided the number of blinks occurs here, so I can only guide you to this extent.
1/26/2018 1:14:20 PM • Sony WEGA... • Answered on Jan 26, 2018
Sony wega kdl-l32mrx1 10 yrs old. picture wont come on display standby light goes green then a crackling sound from the back of the tv, the standby light then goes red again, and flashes 6 times have
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/ Blinking codes details to many popular brand TVs are given. Surf the site with patience.
9/17/2014 10:37:10 AM • Sony WEGA... • Answered on Sep 17, 2014
Tv truns it self off
Check and replace the damaged component/s at its main board. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
8/6/2014 2:11:45 PM • Sony WEGA... • Answered on Aug 06, 2014
2answers
Sony wega television ldm 3210
brauhen resiver fon lcd kabel
9/10/2013 3:05:54 PM • Sony WEGA... • Answered on Sep 10, 2013
I need a sony wega KDL32XBR950 media reciever cant
I have a Sony KDL32XBR950 LCD Wega flat screen TV receiver box that was left behind when our house was robbed. If your still looking for one, let me know, and you can have this one.
1/20/2013 4:15:43 AM • Sony WEGA... • Answered on Jan 20, 2013
0answers
0answers
Can't get TV to Video
check the video input selector from the menu program you should be able to select video2 from there, or it may utilize a different channel on tv such as aux1 or component1 etc. refer to tv owner's manual for further info.
10/17/2010 10:33:31 PM • Sony WEGA... • Answered on Oct 17, 2010
Hi there, I have the same model display unit but with no receiver box. Did you manage to fix your display? It may not be a direct solution, but if you have the receiver box and arent using it then I would gladly buy it from you, and you could then put that towards a new one? A long shot, i know, but my screen is completely useless without! All the best
8/24/2010 6:48:51 PM • Sony WEGA... • Answered on Aug 24, 2010
Sony kdl 32 inch lcd tv (apprx 2.5 yrs old)
Usually resetting a device like that is done via it's On Screen Display (OSD). Maybe you need to contact Sony Tech support.
You can do this by clicking the below link:
[Sony Tech. Support]
Let me know if they have a solution to your problem.
Greetings,
DarkNeogen
1/25/2008 9:18:46 AM • Sony WEGA... • Answered on Jan 25, 2008
Tv wont come on
There might be a problem with your television. When the LEDs do something they never though in normal operation it usually is a status indicator.
Try contacting Sony on the matter as for they probably know what the LEDs indicate. You can find contact information on the Sony websites.
Need help finding contact information? Click link below.
[Contact Sony Tech. Support]
Let me know if this has helped you out. Please rate.
Greetings,
DarkNeogen
1/25/2008 9:14:11 AM • Sony WEGA... • Answered on Jan 25, 2008
Problem with Sony KDL-46VL160 46 in. HDTV TV
The problem in most of the case are: 1. Interference from a defective fluorescent lamp at your room sending signals to the infrared receiver of the TV. 2. Defective infrared receiver itself that sending noisy control signals to the CPU. 3. Defective manual control withes it has leakage. 4. Water damaged control switch PC board.
10/30/2017 1:46:11 AM • Sony KDL... • Answered on Oct 30, 2017
Kdl freeze and reboot on extra channels
Do a reset to this TV, and then check. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
6/29/2017 8:12:31 AM • Sony KDL... • Answered on Jun 29, 2017
Sony Bravia KDL46HX820 powers off and throws 4 blink and pause error
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electro-medical.blogspot.com/ http://homenol.blogspot.com/ http://electronicshelponline.blogspot.com/
6/9/2017 2:20:38 PM • Sony KDL... • Answered on Jun 09, 2017
Sony kdl48w600 no picture with sound
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board....
12/13/2016 3:24:34 AM • Sony KDL... • Answered on Dec 13, 2016
SONY KDL52XBR3 TURN OFF AND STAND BY LED BLINK 7 TIMES IS AU BOARD BAD OR POWER SUPPLY.
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/ If blinks continue without any pause, the main board is faulty. Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
11/18/2016 3:04:40 AM • Sony KDL... • Answered on Nov 18, 2016
Sony WEGA KDL-32XBR950 32 in. LCD HDTV Logo
16 questions posted
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
KDL Sony
  • KDL Sony
Most Popular Question
sony wega television ldm 3210
  • Televison & Video
