20 Most Recent Sony SLV-ED85 VCR Questions & Answers
I need video head for Sony SLV-ED85
You might get one form Curry's Partmaster site.
5/6/2011 11:31:06 PM • Sony SLV-ED85... • Answered on May 06, 2011
Video tape ejects itself
not to overlook the obvious but check to make sure the record safe tab is still on the tape. (little black tab on lower left corner on back of tape)if tab is gone the machine will not go into record mode.
3/16/2007 10:31:27 AM • Sony SLV-ED85... • Answered on Mar 16, 2007
My sony tv bravia model klv 32v400A has no picture but the mauns light turns from red to green using the remote. What is the problem please?
If your Sony Bravia KLV-32V400A TV is turning on with a green pilot light but there is no picture, there could be several potential causes for this issue. Here are some detailed explanations and potential solutions: Check the input source: Ensure that the TV is set to the correct input source. Use the remote or the buttons on the TV to cycle through the available input options (e.g., HDMI, AV, Component). Sometimes, the TV may be on the wrong input source, resulting in a blank screen. Check the video cables: Verify that the video cables connecting your TV to external devices (e.g., cable box, DVD player) are securely connected. Ensure that the cables are not damaged or loose. Try using a different set of cables or connecting to a different input port on the TV to see if the issue is related to the cables or the specific input. Adjust display settings: It's possible that the TV's display settings are not properly configured. Using the remote, access the TV's menu and navigate to the display settings. Ensure that the brightness, contrast, and other picture settings are properly adjusted. You can try restoring the default settings or adjusting the settings to optimize the picture quality. Perform a power cycle: Turn off the TV and unplug it from the power source. Wait for a few minutes, then plug it back in and turn it on. This can help reset the TV's internal components and potentially resolve any temporary issues. Reset the TV to factory settings: If none of the above steps resolve the problem, you can try performing a factory reset on the TV. Keep in mind that this will erase any customized settings and restore the TV to its original factory settings. Refer to the user manual for instructions on how to perform a factory reset. Contact Sony customer support: If the issue persists after trying the above steps, it's recommended to contact Sony customer support or consult a professional technician for further assistance. They will have access to specific troubleshooting steps and can provide guidance based on the model and technical specifications of your TV.
4/20/2024 2:28:26 PM • Sony Televison &... • Answered 14 minutes ago
Sony HT-CT260 Home Theater Soundbar. Missing the manual for it?
Question edited for clarity, proper name, fix typo. Manual and Reviews
Manuals for HT-CT260
Sony https://www.sony.ca > electronics > support > product Find instruction manuals and brochures for HT-CT260.
Sony HT-CT260 review: Excellent sound that fits nearly ...
CNET https://www.cnet.com > reviews > sony-ht-ct260-review May 7, 2013 - The Sony HT-CT260 is our go-to budget sound bar pick, with excellent sound quality, built-in Bluetooth, an adaptable design, and no major ... Rating: 8.4/10
Sony HT-CT260 Home Theater Soundbar Review
PCMag https://www.pcmag.com > Reviews > Audio > Speakers Feb 28, 2013 - The Sony HT-CT260 soundbar adds Bluetooth to an already highly capable and modestly-priced two-piece audio system. MSRP $299.99. Pros and cons: Excellent value ? Built-in Bluetooth ? Treble response isn't the clearest ? View full list Rating: 4 · ‎ Review by Will Greenwald · ‎ US$225.00 · ‎ Out of stock ..
4/6/2024 7:46:33 PM • Sony Televison &... • Answered on Apr 06, 2024
Codes for SONY TV on CYBERTEC REMOTE RM-L1107+3??? Pls help!!!
Pano po ireset ang cybertec 8 in 1? Salamat po
3/19/2024 11:52:38 PM • Sony Televison &... • Answered on Mar 19, 2024
Sony older model with side speakers flashes red led after blinking green here a grinding sound when powering on
All questions need 'make model (what is is)' as first 3 words in every question please. Television? Stereo? Sound bar? ICE? The grinding noise makes me think you have a cooling fan issue, in which case the flashing LED would be signaling an overheat situation. You can Google sony model blink codes ..
3/18/2024 7:02:45 PM • Sony Televison &... • Answered on Mar 18, 2024
I NEED CODES FOR MY NEWSTAR NTR-B28Z FOR MY SONY TV
ChatGPT 3.5
User
I need code for newstar ntr b28z for my Sony tv
ChatGPT
Unfortunately, I can't provide specific code for your Sony TV remote without knowing the exact model number. However, you can usually find the code in the user manual of your Sony TV or by contacting Sony customer support. Alternatively, you can try using the auto-search feature on your newstar ntr b28z remote to find the correct code for your Sony TV.
User
ChatGPT
To find the code for your Sony TV using the Newstar NTR B28Z remote, you can try these general steps:
Turn on your Sony TV.
Press and hold the "TV" button on your Newstar remote until it blinks twice.
Enter the code for Sony TVs. Some common Sony TV codes are: 0000, 0011, 0080, 0111, 1234. If none of these work, you can proceed to the next step.
Press the "Power" button on the Newstar remote. If the TV turns off, the code is correct. If not, try a different code.
Once you've found the correct code, press the "TV" button again to lock it in.
If none of the provided codes work, you might need to consult the manual of your Newstar remote or contact their customer support for assistance.
3/7/2024 2:17:41 PM • Sony Televison &... • Answered on Mar 07, 2024
Circuit diagram of sony kv-sz25m80
str no
2/26/2024 4:44:54 PM • Sony Televison &... • Answered on Feb 26, 2024
I have a Sony Bravia model no klv-22bx350 powers on them shuts down blinks 2times
2 red light blinks can mean a power supply problem that can be caused by a problem on the main board. An authorised Sony repair shop can fix that for you.
2/20/2024 8:03:27 AM • Sony Televison &... • Answered on Feb 20, 2024
Samsung Remote AA59 00443A to Sony NS315?
Question edited for clarity and typos. No it can't be done. These are remote specifically made for one product and are not a Universal Remote. Makers don't play ball with other makers. The only exception is cable and satellite boxes allowing their devices to be co-controlled. https://www.google.com/search?q=sony+ns315+replacement+remote+control https://www.google.com/search?q=Samsung+remote+aa59+00443A ..
2/6/2024 8:24:03 PM • Sony Televison &... • Answered on Feb 06, 2024
Sony bravia codes for universal remote
You can find the codes you need to program your remote control on the official Sony website. Simply enter your model number in the search box to get started. Remote Control Codes & Programming (sony.com) Alternatively, you can try using one of the following codes to program your remote: 262 or 243 or 1071, 5321, 4981, 5811, or 1901
1/20/2024 9:14:57 PM • Sony Televison &... • Answered on Jan 20, 2024
MHC-VX301 STK NUMBER i want to change my stk so i want to know whats the stk number of sony MHC-VX301
It is printed on the output IC. The STK402 was obsolete back in 2012.
1/19/2024 7:16:06 AM • Sony Televison &... • Answered on Jan 19, 2024
3answers
I have a Sony Bravia 4K TV. Trying to download HBO now. Error code 920 keeps popping up.
Okay, Follow these steps to fix out this issue: METHOD 1: Re-installing the application Step 1 - Go to the application that you got the error with. Step 2 - Open that application download page on the Play store. Step 3 - Uninstall it or even uninstall all the update (If the error came when you were updating the application). Step 4 - Now you clear the task manager and try installing it once again. If the play store error 920 doesn't come then you have solved the problem and now wasn't that easy. So it's always best to try this step before doing anything else. METHOD 2: Switching off and turning the wifi (cellular data) on Step 1 - To remove that load Just turn your wifi off and then turn your wifi on (the same goes with your cellular data). Step 2 - Now after doing this go to your Play Store application and download the application that you were going to download. Now your Play Store Error 920 won't be bothering you anymore. METHOD 3: Clearing the cache and data of Google Play Store Step 1 - Go to settings of your device. Step 2 - Now find "Applications" option under the settings menu. Here you can find "Google Play Store" option. Open it. Step 3 - Now, at the bottom, you can find "Clear Cache" option. Tap on it and your all cache will be cleared. METHOD 4: Removing and adding back your Google account Step 1 - go to Settings of your Mobile. Step 2- Now, find "Accounts" and then go to "Google Accounts". Step 3 - In that section find the account you use for the play store or the account that you were using while the error came in. Once you tap on your specific account you'll find an option to remove the account. Tap on it. Step 4 - Now you have successfully removed your account and after that re-add your account. After entering your email id and password and hence adding your account. Go back to the play store and find the application that you were downloading or updating when the error code 920 came in. Now re-install it or update it back again. This time you won't be faced with the play store error 920. For any help visit us: Hbo Go Help
1/18/2024 2:22:16 AM • Sony Televison &... • Answered on Jan 18, 2024
2answers
BDV E2100 LOCKED IN TV MODE
Once again a simple GOOGLE search, and the first thing on the list is the manual for this unit! I suspect this is what you need. Deactivating the Buttons on the Unit (Child Lock) You can deactivate the buttons on the unit (except for on/off) for preventing misoperation, such as child mischief. Hold down (stop/square black button) on the unit for more than 5 seconds."LOCKED" appears in the front panel display. The child lock function is activated and the buttons on the unit are locked. (You can operate the system by using the remote control.) To cancel, hold down (stop/square black button) for more than 5 seconds until "UNLOCK" appears in the front panel display. If that's not the problem, here's the link for the manual. http://pdf.crse.com/manuals/4446734151.pdf
1/16/2024 7:52:33 PM • Sony Televison &... • Answered on Jan 16, 2024
Code for Sony tv? I am using a universal remote Keyin RM-168E.
All about Universal Remotes and why in 2024 no one uses them!. https://www.fixya.com/support/r29872378-universal_remotes_no_facsimile_remote SONY 3 & 4 digit universal codes are 002, 000, 011, 080, 111, 006, 071, 128, 1904, 925, 0000, 0834, 0810, 1685, 1786, 1032, 1972 ..
1/6/2024 4:53:32 AM • Sony Televison &... • Answered on Jan 06, 2024
Power on batn red,and green light blinking note power on sony HCD-GN1200D
See page 72 of user manual. It will help. MHC-GN1200D/GN1100D (sony.com)
12/29/2023 8:14:02 PM • Sony Televison &... • Answered on Dec 29, 2023
Sony mhc rg490s stand bye flexing only
12/13/2023 1:33:18 PM • Sony Televison &... • Answered on Dec 13, 2023
Sony SLV-ED85 VCR Logo
2 questions posted
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Televison & Video
Most Popular Question
video tape ejects itself
  • Televison & Video
