20 Most Recent Sony KP-53S70 53" Rear Projection Television Questions & Answers
Look to see if set on the remote has a ZOOM or aspect button--model indicated here should not have that feature but others do, also look for that on the remote if a cable or sat box is being used.
Sony KP-53S70... | Answered on Oct 26, 2012
The Standby/Power light of the TV blinks when there is any internal malfunction in the TV. The self-diagnostic function of the TV will cause the STANDBY light to blink or flash when the television detects an issue. The number of times the STANDBY light flashes corresponds to a specific issue.
Few examples are given below; some of the issues may be resolved without the need for service.
1 blink / 2 blinks / 5 blinks: - This indicates that there may be a power-related problem with your set.
3 blinks: - This indicates that there may be a power-related problem with your set. The set will need to be serviced to allow a technician to determine the specific issue that needs to be repaired. If the power light flashes three times in sequence in a Lamp TV, the lamp cover is not securely attached. Reattach the lamp cover to resolve this issue.
4 blinks: - This indicates that there may be a back light or lamp power problem.
6 blinks: - This indicates that there is some kind of audio problem with your set.
7 blinks: - This indicates that there is a temperature problem with your set. Please check to make sure that the air vents on the sides and back of the set are not blocked or clogged and there is adequate ventilation around the television. We recommend that you check and clean the vents periodically to make sure the set receives adequate air flow. If the problem continues, the set will need to be serviced.
8 blinks: - This indicates that there may be a video-related problem with your set. If the flash sequence is not listed above or the light continues to flash, follow the steps below to perform a power reset:
Try the following steps to check if the issue can be resolved.
Turn off the television.
Unplug the television power cord from the electrical outlet.
Let the television remain without power for 60 seconds.
Plug the power cord back into the electrical outlet.
If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
If the issue continues to occur, service may be required.
Thanks for using Fixya.
Sony KP-53S70... | Answered on Jul 17, 2011
Check this link, usually if the power light blinks a certain amount of times its a code. I have a sony TV also and it did the same thing turned out it the lamp need replacement.
http://www.agoraquest.com/searchbb.php?term=sony%20tv%20flashing%20red%20light%203%20times&addterms=all&forum=all&submit=1&sortby=p.post_time&min_num=20
Sony KP-53S70... | Answered on Jun 11, 2011
YOU NEED TWO CONVERGENCE AMPS STK392-570 CHECK THE LAST THREE NUMBERS ON THE ONES IN YOUR SET REPLACE THEM BOTH
Sony KP-53S70... | Answered on Mar 29, 2011
All projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Sony KP-53S70... | Answered on Jan 13, 2011
U have a LED light indicator said lamp on ur tv?It is blinking?If the LED indicator said lamp is blinking.Than yes,ur projection bulb require changing.Yes replacing bulb pretty easy.
Sony KP-53S70... | Answered on May 01, 2010
It is pretty clear something was jarred loose during the move; these are pretty delicate devices. You should NOT try to repair this yourself. These types of televisions can have LETHAL voltages inside for WEEKS after they are unplugged.
Sony KP-53S70... | Answered on Jan 09, 2010
Hi,it sounds like you lamp went bad.If your tv is between 2-4 yrs it will be the lamp that needs replacement,The red indicator is indicating there's an issue with the lamp.Try this websites discount-merchant or, discounttvlamps, They carry the original brands.
Sony KP-53S70... | Answered on Oct 05, 2009
you have a bad crytical safety cap.replace C517 value 102k at 2kv.
Sony KP-53S70... | Answered on Sep 19, 2009
you can look at the deflection board for a burnt up little blue capacitor, it will be 1picofarad at 2000 volts, if it's not that obvious, then you will need convergence chips or a flyback, you just can't troubleshoot that problem yourself.
Sony KP-53S70... | Answered on Sep 15, 2009
Try here: http://www.tritronicsinc.com/
Or try here, they seem to be able to find hard to find replacement parts, including lenticular screens for Projection TVs:
http://www.tvscreenfinder.com/services
Sony KP-53S70... | Answered on Dec 17, 2008
Unfortunately, you apparently got information from someone who has not had training on your set. A 4 flash on your set indicates a vertical stop, meaning that the vertical drive circuit has shutdown. Possible causes are a bad vertical drive or vertical output IC. I can't be more specific because I would have to check a couple of things, starting with the 135 volt power supply line to see if it is coming up. You can stop looking for a cooling fan because this set does not have one.
Sony KP-53S70... | Answered on Nov 12, 2008
Sony KP-53S70 53" Rear Projection Television Logo
32 questions posted
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Televison & Video
Most Popular Question
kp53s70 problem picture colors dont
  • Televison & Video
