20 Most Recent
Sony KP-41T35 41" Rear Projection Television Questions & Answers
My sony kp-43475 projection tv
Your convergence has failed and needs to be repaired. Once quick test is to goto your convergence menu and see if you can adjust red and blue. If not its has failed and needs to be fixed. You can call in a repair shop or you can get the parts and instructions from www.TvRepairKits.com and do the repair yourself. Its a fairly easy DIY fix.
The box on the back of tv that the coax cable
You can buy the RF jack and solder it back onto the tuner as long as the tuner has not been damaged beyond repair. Inside the tuner the center conductor from the jack solders into the printed circuit board. If any small parts are broken or missing then you will have to replace the tuner.
Hi, we are getting blurry double vision with some
Bad convergence ICs replace Both they are big Black ICs will have part number on them STK392-150 also CK pico fuses 5amps 6amps they will look like resistors but are green or yellow around STKs for Parts call mats electronics 1-800-628-1118
MY SONY KP41T35 PIC FLASHES ON OFF ON OFF AND
Sony PTVs do get bad CRTs, to confirm you can pull the front cover and tap on the middle CRT (green) neck with a plastic handle if the green screen flashes back to normal or brighter and causes the TV to shutdown then the CRT is bad. sometimes you can make it stay working for awhile, but eventually the CRT will need replacing. if this doesn't help you can turn the bottom middle control counter clockwise to lower the green .
hope this helps
Eric I’m happy to help further over the phone at
https://www.6ya.com/expert/eric_ab7c09ec01841771
I NEED CODES FOR MY NEWSTAR NTR-B28Z FOR MY SONY TV
ChatGPT 3.5
User
I need code for newstar ntr b28z for my Sony tv
ChatGPT
Unfortunately, I can't provide specific code for your Sony TV remote without knowing the exact model number. However, you can usually find the code in the user manual of your Sony TV or by contacting Sony customer support. Alternatively, you can try using the auto-search feature on your newstar ntr b28z remote to find the correct code for your Sony TV.
User
ChatGPT
To find the code for your Sony TV using the Newstar NTR B28Z remote, you can try these general steps:
Turn on your Sony TV.
Press and hold the "TV" button on your Newstar remote until it blinks twice.
Enter the code for Sony TVs. Some common Sony TV codes are: 0000, 0011, 0080, 0111, 1234. If none of these work, you can proceed to the next step.
Press the "Power" button on the Newstar remote. If the TV turns off, the code is correct. If not, try a different code.
Once you've found the correct code, press the "TV" button again to lock it in.
If none of the provided codes work, you might need to consult the manual of your Newstar remote or contact their customer support for assistance.
