20 Most Recent Toshiba PDR-2 Digital Camera Questions & Answers
manual
Need old drivers and software for Toshiba Pdr-2 digital camera..
Hello , I am in need of software for my toshiba digital camera PDR 3330. I need to instal the pictures to my pc. can't find any software , please help......... where can I get
3/27/2008 9:23:09 PM • Toshiba PDR-2... • Answered on Mar 27, 2008
Card Error
If you should see the warning message "CARD ERROR" in the LCD Display, please check the following: Always choose reliable quality SD Cards. Toshiba Digital Cameras are tested for maximum performance with Toshiba SD Cards, Delkin SD Cards and Panasonic SD Cards. These are leading brands in the development of standard SD technology. Performance by other brands of SD cards may vary. Check the LOCK switch on the SD Card. The camera can not save images to an SD Card when it is in the lock protected position. If the SD Card is NEW, it may be necessary to FORMAT the card. This only applies to NEW SD Cards. If you format a card with images, all images will be erased. You can FORMAT your card periodically to maximize capacity and erase 'unseen' files, please be sure to download all images before choosing FORMAT as all images will be erased. Your Toshiba Digital Camera is designed for use with SD Cards. MultiMedia Cards are similar in size and shape to SD Cards, although with close inspection you will find that SD Cards have a different 'PIN" connection configuration, are slightly thicker in size, and have a manual slide LOCK switch on the side. Toshiba Digital Cameras are not designed or guaranteed to accept MultiMedia Cards. Please be sure to look for SD Cards from Toshiba, Panasonic and Delkin, the leaders in SD Card Technology.
9/11/2005 10:26:13 AM • Toshiba PDR-2... • Answered on Sep 11, 2005
My Toshiba Camileo HD-DV Camcorder won't focus
If your Toshiba Camileo HD-DV camcorder is not focusing properly, there are a few potential causes and solutions to try:
  • Check that the lens is clean and free from any smudges or fingerprints. Even a small amount of dirt or debris on the lens can affect the focus. If the lens is dirty, try cleaning it with a lens cleaning solution and a microfiber cloth.
  • Make sure the lens is not blocked by any foreign objects, such as the hood of a camera bag or the edge of a cap.
  • Try adjusting the focus manually using the focus ring on the lens. If the focus ring is not responding or is difficult to turn, the lens may need to be serviced.
  • Make sure your camcorder firmware is up to date. Check Toshiba website to see if there is any update available and instructions on how to update.
  • Make sure the camera is not in macro mode. Some cameras have a separate macro mode that enables the camera to focus on objects that are very close. If you are not trying to take close-up shots, you may need to switch out of this mode.
  • Make sure the scene is well lit. Low light can make it more difficult for the camera to focus, try adding more light to the scene or use the manual focus.
If none of the above steps work, it is possible that the camera's autofocus system may be malfunctioning and will need to be repaired. It's best to contact Toshiba customer service or a local camera repair shop for a diagnosis and estimate for repair if the issue persists
1/12/2023 12:35:19 AM • Toshiba Cameras • Answered on Jan 12, 2023
How does is the right setting of Toshiba refrigerator display setting
This is not a camera. Why post in the Camera queries forum ?
12/8/2021 11:25:12 AM • Toshiba Cameras • Answered on Dec 08, 2021
Toshiba tv 43u2963db
a) This is not a camera b) Have you looked in the manual ?
11/30/2019 12:00:25 PM • Toshiba Cameras • Answered on Nov 30, 2019
I have a Toshiba PDR2300. I get card error and can't take pictures. How do I fix this?
Discover what the error is with the card and correct it. The card could be corrupted, an incorrect storage capacity, write-protect could be set, or it could be full.
4/8/2017 12:00:53 AM • Toshiba Cameras • Answered on Apr 08, 2017
I'm having a problem with
As you yourself have said, this is NOT a camera. For help, I would advise you to post this in a forum dealing with computer equipment.
3/10/2017 11:42:30 AM • Toshiba Cameras • Answered on Mar 10, 2017
I need a price check on a Toshiba CMOS digital still. Camera price check please
Fixya does not offer advice on pricing equipment. Check on Ebay to see how much similar items are being advertised for.
12/16/2016 9:14:30 PM • Toshiba Cameras • Answered on Dec 16, 2016
Ineedtoget my Toshiba TV and my digital stream converterbox
You need to get them to do what, exactly ? Dance ? Make coffee ? Breed ? Can you be more specific, please ?
11/11/2016 11:25:56 AM • Toshiba Cameras • Answered on Nov 11, 2016
I have a Toshiba DKT2020F-SD and would like to always have my phone on call-forward to my mobile? Please help
Look in the front of your phone directory to find out how to do call forwarding in your area, or call land line phone company and ask them.
11/2/2016 11:11:07 PM • Toshiba Cameras • Answered on Nov 02, 2016
0answers
0answers
Toshiba PDR-2 Digital Camera Logo
3 questions posted
Top Toshiba Cameras Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Toshiba Camera Expert? Answer questions, earn points and help others
View Most Popular
Toshiba Cameras
  • Toshiba Cameras
Most Popular Question
need old drivers software toshiba pdr 2
  • Cameras
