20 Most Recent
Kyocera Loft / Torino S2300 Questions & Answers
Want to download by usb cord from loft to computer program or copy to cd
Here are my suggestion to solve your problem:
If your computer is Bluetooth-enabled, you can use the file exchange capability of Bluetotooth to transfer files between your computer and your phone - no cables/wires needed.
If your computer is not Bluetooth-enabled, you could buy a USB Bluetooth adapter for it.
Hope this helps.
How do i unlock kyocera torino s2300 when i have forgotten the password
ur defalt phones codes is 12345 or 00000 u can use it Default 4 Digit user code: 1234 or 0000Default 6 Digit Security code: 123456 or 000000Type *#06# at the mobile screen to know IMEI no of your mobile.send the IMEI no to me and i will reply you with unlocking code.IF Problem not Solved SoPlease New Software install in the Phone Problem will SolvedIf For puk & pin cod problem So PleaseVery Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office opratorEnter The Puk code and YesEnter The pin code and YesSo Puk code Open and Problem will Quickly Solved
Keypad lock
At the home screen, you activate the keyguard when you press and hold the Back key. From the home screen, select Unlock and press the Back key to unlock the keypad.
Need to deactivate my phone now
Dear friend,
You can not deactivate your mobile for short time, but if yiu don't want to receive calls and use your phone at the same time then switch to flight mode profile.
After activating flight mode, when someone calls you they will be notified that your mobile is switched off!
For more help, reply me wih full detail and your mobile model no.
Regards,
Priyank Abhineet.
