20 Most Recent
True 23 cu. ft. / 651 liter Commercial Freezer GDM-23F Questions & Answers
The fan on my true
Are you talking about the fan inside the freezer? If yes, check the following items. The door has a switch that turns the lights off when the door closes, it also turns the fan off when you open the door. If it isn't working right the fan won't come on. There is also a round temperature senser on the coil inside the freezer called a "clickson" that keeps the fan from coming on until the coils are below 20 degrees, it may be bad. If you are low on freon, your coils may not be getting cold enough to trip the clickson. Feel of the small copper line going from the compressor to the coils on the outside of the freezer. It should be almost hot enough to burn your skin if you have enough freon. One other thing to check is the defrost timer. It is a box about 4 inches wide and 8 inches tall with a door on the front of it. Check the connections inside to be sure you are getting power through to the fan. Let me know how it turns out.
My freezer does not work all of the time. I HAVE
The first thing to check is the condenser coil at the bottom of the freezer. Take the slatted front cover off at the bottom where the compressor is located. You will see the conderser coils. This looks like a radiator with aluminum fins, about 16 by 16 inches square. Be sure the coils are clean. Since the compressor is close to the floor it pulls a lot of dust into the coils. You may need to take a long stiff bristle brush to get as much dust as possible off the coils. If this is stopped up, the unit will definately overheat very quickly. While you are down there make sure the fan behind the coils is running. There are several reasons the fan might stop running. The motor can burn out, something can impede the fan blades such as paper, or sometimes rodents. If the fan isn't running the compressor will overheat and shut off. Once you check these basic things, you may then have to address the problem of dissapating the heat. The answer to your question is yes, it will shut down if it gets too hot. You need plenty of air space behind and over the unit in your situation. The air needs to flow into the front bottom section of this unit and flow freely out the back. All commercial refrigeration is designed to operate in 75 degree areas. As your room temperature increases the efficiency of the freezer will decrease. It is not uncommon to find these units in kitchens where the temperature is 85 even 90 degrees. They will continue to work, but will probably run all the time. I would think if you could get 3 to 4 inches of space at the back of the unit and the two feet above the unit with clean coils and properly running fans, you should get better results. You MUST have free flowing air to keep the unit running. The ideal situation is to have the air flow directly through from front to the back of the compressor compartment. In your case, you may have to move the freezer away from the back wall and allow the air to flow up the back of the freezer and out over the top into the room. 2 inch holes are not enough.
Light removal
get a screw driver and loose the light holder and replace it a new one bought .
Lights wont come on in the cooler
underneath the unit in the metal box there is a ballast for the lights check it to see if it is getting power and or producing power to the bulbs
Kenmore commercial upright freezer not sealing well - thawing
If the door seal does not seal completely, replace it. This is very important for freezers.
Contact Rick at Restaurant Parts and More.
\1-888-814-1110. He can most likely get what you need. Just have model and serial numbers and he'll do the rest.
Home Depot and Lowes is a definite no.
No door heat
The Mulluen heaters will be Built into the frame not in the door.
On freezer True T-23, the compressor works around 5 minutes and turn off for around 5-6 minutes and start again for another 5 minutes. I need help
That is what it is supposed to do. It is called cycling and switches off when the set temperature is reached. It is a commercial freezer, so if the door opened and closed often, that is normal?Commercial freezers and fridges have an item called a 'Clixon' that cuts power in the case of the compressor overheating. When was the last time the fins on the compressor coils were cleaned? Could also be a bad door seal letting cold air escape. When you close a freezer door on a unit like that, it should be really hard to open straight afterward due to the suction. Could be a faulty thermostat. Turn the temperature to the warmest setting and see if it still does it? If it does, you need a new thermostat.I just retired after 52 years in catering.https://www.katom.com/598-T23F.html?gclid=CjwKCAiArbv_BRA8EiwAYGs23PKtEzF60_OMVNpHXBlGjHQNdpp0pDZsu0G0lFLqVy2p4qIybG9n8xoCwEMQAvD_BwE..
Why is jenn air jcd2389ge hot around front freezer door frame?
The heat at the opening of refrigerator is usually a sign the condenser coils are dirty. Check the condenser coils for a restriction underneath the unit. Dirty condenser coils will cause poor air flow over the coils and compressor. Poor air flow will cause a lot of problems, including overheating the compressor, the refrigerant and the copper lines. This will destroy your sealed system. The coils need cleaning at least once a year, more often if you have pets.
I couldn’t determine if your unit has an “energy saver” setting. If so, turn it on. Not all refrigerators have energy saver. This is on units with emilion heaters in the wall around the door gaskets. The heaters are to eliminate condensation around the door. Turning ON energy saver turns OFF those heaters. You should notice a change quickly if it’s the heater causing the heat, that is, if you have that model.
Cleaning the coils will need a day or two to allow things to cool down before you notice a change in the heat around the door.
True 49f fans stopped running.
Compressor still runs. Fixes? Troubleshooting steps?
I am assuming you are relating to the evaporator fan(s) not running. If this is the case, some units have a 'Klixon" type thermostat in the evaporator so when the evaporator coil temp reaches a predetermined temperature, the fans come on. You may have a bad "Fan Delay" (Klixon) or the coil is not reaching the proper temp to activate it to turn on the fans. I would check the wiring diagram on the unit for this part to see if this unit has it in the system.
