20 Most Recent
Apple iPHONE 2G 8GB Questions & Answers
Iphone 2g won't turn on
Hello, friend! I also meet this error about my cell phone, I get many help from this forum, and also bought many DIY repair tools from china supplier , and vipprogrammer help me fix this error. maybe you can try it.or contact ther WhatsApp:+ 8615986801289 website: http://www.vipprogrammer.com. They've solved my cell phone problem and I hope it will help you with your mobile phone trouble.They have professional unlock tools.
IPhone 2 displays no service when I put my SIM card from a different phone.
the phone is locked to your sin only. apple made this so if the phone is stolen it will not work with another phone. if you are changing your sim you need to do this. Press home volume down and power when phone comes on take finger off power then volume then home. plug into itunes and restore software after it has installed click on new this will wipe phone to new after you can put your stuff back on with itunes all apps and contacts that have been saved to itunes. with your new sim installed
Iphone
is it supported? and it also might be that the sim card is unreadable or damaged. try using it on another iPhone and if the problem is with the sim card then get a new one but if its the phone then try restoring it or take it to apple to see if it needs a sim card slot repair
Iphone 2g
try charging overnight and if that doesnt work then the battery might be damaged
Adding songs
You just need to import your songs into iTunes library, then make a playlist with the songs, connect your iPhone to computer, iTunes will detect the iPhone automatically, then click iTunes menu "File -> Sync iPhone ", the songs will be transferred from iTunes to iPhone. If you want to know how to put DVD movie on video on iPhone, this tutorial will help you a lot.
http://www.dvdtoiphone3gs.com/how-to-play-dvd-video-on-iphone.htmlHope
it helps. Contact me if you have any other question.
Can't type 0
More likely a "Fat Finger" issue, I have that problem all the time, try using your pinky finger to test this problem. If this don't work, then maybe the sensor in the part of the unit is shot. How old is it, is it still under warranty?
Iphone 2g power button
If your power button is broken and you can't turn it on, try connecting it to computer with usb, it may turn it on by itself.
How do I know when my phone is charged or charging?
chances are your battery is toaste, most are lythium ion bateries. oncve the charge is brought down so far, the battery will not have enouph power to transmit a signal to the charger to tell it that it is conected and to charge. i personaly hate buying batteries. there is a fix but its for sure. iff you cna find another battery, (normal battery like a 9volt or a aa,aaa,c, or D cell,) you can can manualy transfer power to the lythium batery to give it enouph charge toi register that it is there to the charger. try taking the positive side of the good battery and ,with a small wire, conecting it to the negitive side of the dead battery, and fron the negitive side of the good battery to the positive side if the cell battery, for about 30 sec,. then place the cell battery back in the phone and see iff it will charge...im assuming you have completly dried and ventalated your phone....good luck!
I can not take video record
the iphone 2g will not record .. there is a app that you have to buy to use video record... the videos will go into your pictures libary however you can upload them via iphoto or email it to yourself / facebook upload/ youtube just be on wifi before doing it to make it go faster / and save data if you dont have unlimited data or **** data from simple mobile/ tmobile / or a weak 3g network verizion and att are a bit faster but you want to go on wifi still
I forgot my apple password
To reset your apple password
1 go to settings
2 tap your name>Password & Secretary >Change Password
3 Follow the onscreen instructions to reset your password.
I must reset my apple ID
Hi there, you can try
TunesKit iPhone Unlocker to Remove Apple ID on Apple Cell Phones.
Here a step-by-step tutorial:
Step 1. Connect your iPhone to your computer
First, get your iphone connected to a computer. Then launch TunesKit iPhone Unlocker, and select the Unlock Apple ID option.
Step 2. Setting confirmation
If you have Find My iPhone enabled on your iOS device, you will need to confirm that a passcode is set and turn on two-factor authentication on your iPhone.
If the Find My iPhone feature is disabled on your device, you can skip directly to the next step and tap the "Start" button to unlock your Apple ID quickly without losing data.
Step 3. Remove Apple ID
Once confirmed, TunesKit iPhone Unlocker will start downloading the matching firmware and then remove the Apple ID from your iPhone.
