20 Most Recent Sony TA-N9000ES 5-Channel Amplifier Questions & Answers
2answers
Hello! I have a problem
If the light blinks you need not check the fuse, its an indication that your amp has gone into protection mode due to an output failure. You will have to take it to an authorized service center because the S-master chip is a surface mounted device which needs a specialized equipment for de soldering and soldering.Even an ordinary service technician might refuse to handle this work.
5/26/2020 2:49:19 AM • Sony TA-N9000ES... • Answered on May 26, 2020
2answers
No output.standby switch is blicking
R221 1ω was the problem.
12/5/2014 7:06:36 AM • Sony TA-N9000ES... • Answered on Dec 05, 2014
Standby led blinking, no sound
Acording to the manual you have it in an invalid mode.
11/4/2014 8:11:27 PM • Sony TA-N9000ES... • Answered on Nov 04, 2014
0answers
Hi, My S-Master 5.1 Digital Amplifier can't read
Most disc read errors are caused by dust or dirt on the lens of the DVD player. You should follow the cleaning instructions. Or watch a YouTube video on cleaning DVD lenses.
10/19/2013 3:12:52 PM • Sony TA-N9000ES... • Answered on Oct 19, 2013
2answers
My Sony S-Master 5.1ch full digital amplifier is
When we turn on our 5.1ch Full Digital amplifier, it started smoking and sparks were flying. Can it be repaired
12/21/2012 10:54:57 PM • Sony TA-N9000ES... • Answered on Dec 21, 2012
I have a Sony power
It's just a big amp with no controls you would change during normal operation. There's no remote. You don't name any source or if you even HAVE one attached. THAT would be a good place to look for missing sound.
Register and download the manual for free audio.manualsonline.com http://audio.manualsonline.com/manuals/mfg/sony/sony_ta_tan9000es.html http://dl.owneriq.net/f/fede44fb-b9ba-4e03-87bb-d0f3e29e22ef.pdf Set the BTL/Normal switch on the back to Normal. In fact, any switch or knob with BTL, set it to whatever choice is NOT BTL.
3/24/2011 1:36:35 PM • Sony TA-N9000ES... • Answered on Mar 24, 2011
I am only receiving sound through two right side
maybe the wires are grounded.,., try to yurn the wires from left to right then reverse,.,,
12/28/2010 11:08:02 AM • Sony TA-N9000ES... • Answered on Dec 28, 2010
My digital amplifier S-MASTER,mod HDC-SB300
hi,
may be ur amplifiers any of the output channel have some problem. that's why it goes off after power on, protecting ur speakers. disconnect all the speakers and inputs and then power on it if works check ur speakers and inputs. if not there is fault inside ur amplifier.
ok
12/22/2010 8:56:07 AM • Sony TA-N9000ES... • Answered on Dec 22, 2010
When i start my super
Hi...
#1 Is the subwoofer connected? #2 Try connecting another speaker to see if your original sun is bad If the trouble is still there either you have a power supply failure or one amplifier section that has failed ( needs parts)
10/5/2010 11:34:38 AM • Sony TA-N9000ES... • Answered on Oct 05, 2010
Our S-Master 5.1 ch full
to fix it you would need a soldering iron and some solder. Where is your location so I can set you up with a place to buy a new one?
9/4/2010 8:25:37 PM • Sony TA-N9000ES... • Answered on Sep 04, 2010
Accidentally plug 110v dryer into
The dryer would have burned off the coils as the voltage is double of the operating voltage that was designed. ALl what can be done is to open and find out the break in the heater resisitor winding . These wires act a fuse and would have just burned out and lost the connection. find it out by a continuity test and connect at this point by joining , twisting. Now test the continuity and test on the 110 volt. it must work hope fully if the motor has not burnt out too. Hope you try. Good day..
7/31/2010 11:16:10 AM • Sony TA-N9000ES... • Answered on Jul 31, 2010
I accidentally plugged my 110V amplifier to 220V
Hi and welcome to the site,
Initially, on a completely dead Sony TA-N9000ES, primary suspects to be checked would be:
  • 8A F1 fuse;
  • primary winding of T1 transformer;.
  • fusible resistors R816, R817 and R818.
Good luck and thank you for asking.
7/13/2010 2:27:07 PM • Sony TA-N9000ES... • Answered on Jul 13, 2010
Sony TA-N9000ES Flash light when turn on.
an amp of this size generates alot of heat internally when in use as these use mosfet ICs and can get very hot.
your problem is most definately dry solder joints and possibly quite a few at that.
i've repaired quite a few sony surround receivers with similar problems and have all been down to dry solder joints.
hope this helps.
7/2/2010 11:22:34 PM • Sony TA-N9000ES... • Answered on Jul 02, 2010
The word protect keeps coming up on the screen
This most likely is referring to a protection fault - ie a short circuit. Usually in the speaker wiring, it can also occur inside the unit.
4/2/2010 10:34:51 PM • Sony TA-N9000ES... • Answered on Apr 02, 2010
Volume knob broken
needle nose pliers to turn it down,find another knob there pretty common even if you had to use a drop of super glue.
9/6/2009 5:29:43 AM • Sony TA-N9000ES... • Answered on Sep 06, 2009
Sony TA-N9000ES 5-Channel Amplifier Logo
31 questions posted
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
ZJ Limited
ZJ Limited
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Audio Players & Recorders
Most Popular Question
sony s master 5 1ch full digital
  • Audio Players & Recorders
