20 Most Recent YDI Wireless Extended Range 802.11b Access Point (ap-ant) Questions & Answers
Hi there.
Can you tell me the brand and make please?
Thank you!
YDI Wireless... | Answered on Aug 20, 2011
Press reset button and hold or 10 seconds.
YDI Wireless... | Answered on Mar 20, 2009
Try This:
    • 1 Unplug all cables from the router except the power cable. Power on the router.
    • 2 Locate the reset button. This is typically a small hole marked "Reset."
    • 3 Insert the straightened end of a paper clip or the point of a ballpoint pen into the hole. Press and hold for about 10 seconds. Lights will blink, indicating that the unit is rebooting.
    • 4 Refer to your user's guide and follow instructions on setting up a new router.
YDI Computers &... | Answered on Aug 09, 2012
Fixya is not licensed to practice medicine. Consult a Doctor or at a minimum a pharmacist.
Computers &... | Answered 29 minutes ago
You can do anything you wish with your devices, it is your choice. And it will not replace screen.
Computers &... | Answered 1 hour ago
I want to change a needle from the top
https//translate.google.com
Veuillez utiliser le menu Commentaire pour ajouter des informations afin de clarifier votre question.
Computers &... | Answered 2 hours ago
If your router/network is BT and you accepted to be "a hot spot", others can access your router/wifi, but only a reserved small limit of the bandwidth, and not your password protected part. They certainly can not see or access any of your data being sent or received.
If you have not agreed to being a hot spot, or it is not BT network, it is unlikely that anyone else, with or without an extender can access your router, providing the password is strong enough. Even if they access the router via ip addresses, settings should be protected by your access admin password.
Computers &... | Answered 3 hours ago
carambis updater username and activation key
Computers &... | Answered 4 hours ago
Quel ordinateur, s'il vous pla?t
Computers &... | Answered 10 hours ago
1) How are you powering your laptop?
You did not explain.
Is it plugged into an AC outlet, or is it on battery power.
If AC, is it running through a "surge protector" or power strip?
Is everything else connected to that power strip working?
If battery powered, have you charged the battery for a long time through a reliable source, such as an AC battery charger?
Has the laptop had a spill, been dropped, a hard drive exchange, etc?
I am sorry to say but, I think  your prombelm is that the cpu is the wrong size if you want it to run at that pro speed youneed to get a dual core instead a single core and update the bios then lala linda I hope this helps
Computers &... | Answered 12 hours ago
move to a bigger house
Computers &... | Answered 14 hours ago
Make, model and OS of computer may help you get an answer.
Computers &... | Answered 17 hours ago
YDI Wireless Extended Range 802.11b Access Point (ap-ant) Logo
8 questions posted
Top YDI Computers & Internet Experts
Alun Cox
k24674
Are you a YDI Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • YDI Computers & Internet
Most Popular Question
need drivers usb ant
  • Computers & Internet
