20 Most Recent YDI Wireless USB Client Station 802.11b (USBANT) Questions & Answers
Try This:
    • 1 Unplug all cables from the router except the power cable. Power on the router.
    • 2 Locate the reset button. This is typically a small hole marked "Reset."
    • 3 Insert the straightened end of a paper clip or the point of a ballpoint pen into the hole. Press and hold for about 10 seconds. Lights will blink, indicating that the unit is rebooting.
    • 4 Refer to your user's guide and follow instructions on setting up a new router.
YDI Computers &... | Answered on Aug 09, 2012
No networkable product comes with an IP address, however this has a Wi-Fi network chip in it so it can get an address from the base station allowing it to connect
Computers &... | Answered 4 hours ago
Although there are several hosts available online some provides free web hosting while some offers cheap hosting service but If you ask me than I would suggest you to try a cheap web hosting services like PowerUp hosting, go dady etc. that offers viable and cheap web hosting services.
Computers &... | Answered 9 hours ago
If you are difficulties to select hosting organization, only you have to check the Which organization has best services as well as that offer better service. I have used Power Up Hosting that has given many discounts on his service as well as given few few free services.
There are number of web hosting services available online, depending on what you are need and budget you can select a wordpress host.
If you want fast speed and cheap wordpress hosting, get services from Power up Hosting
I believe you have to "restore it", that is put it in recovery mode. To do that, plug it into a computer with the iPad off. Press and hold down the power button. Continue holding the power button down as a display comes into view. As soon as any display appears, continue holding the power button down as you press and hold down the home button, (the middle button), holding both down for 10 seconds. Release only the power button, continue holding the home button down. The PC should "beep" when the usb is recognized. Release the home button. Your restore should work. Open itunes on your computer. It will ask you if you want to restore. Select yes. When itunes finishes, your ipad should work again.
Do you mean the Azpen A1042 tablet, https://www.azpeninnovation.com/products/azpen-a1042-10-inch-tablet ? If so, Azpen has user guides for their tablets based on the OS version on their support site: https://www.azpeninnovation.com/apps/help-center/#!guides . Marshmallow is Android 6.0; thus the current link to the manual is https://cdn.shopify.com/s/files/1/2283/9481/files/Android-6.0-Manual.pdf?13965626407600149002 .
There is a recessed Reset button on the tablet. You can try press this with a pin to see if that solves the problem. Otherwise, you may be looking at a switch or backlight problem. Another possible issue is that the tablet may have damage to the memory and can't boot up.
I hope this helps.
Computers &... | Answered 11 hours ago
we dont
howsaboutyouusethedamnspacebarandthenmaybewewillthinkaboutit??
YDI Wireless USB Client Station 802.11b (USBANT) Logo
0 questions posted
Top YDI Computers & Internet Experts
Alun Cox
k24674
Are you a YDI Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • YDI Computers & Internet
Most Popular Question
ydi ap plus won 39 t reload factory
  • Computers & Internet
