20 Most Recent
Sony RM-V202 Remote Control Questions & Answers
Code to be set in Multi Brand Remote Commander for SAMSUNG TV
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://homenol.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Search the site by type in the "
brand name" to your device; to which you want set-up codes; in the "
Search box at the top right of the display window" to get gathered related posts.
Need code for programming rca tv wiht a sony
find the correct code automatically.Turn on your device.
while pressing SET botton press POWER, and release them ,then press CH+,then release it
Then press POWER repeatedly untill your device responds.don't go too fast.
When it responds press ENTER to store the code.
I need the code for the digital strwam converter
The remote that came with your DTV Converter Box may not control some TV brands.
Be sure to follow the remote control programming instructions below, or
see your Install Guide for specific brand programming codes.
If you cannot control your TV with this remote, we recommend you use
the remote control that came with your TV separately,
or buy a universal remote that can control the TV as well as your converter box. (Refer to the previous question.)
Trying to program sony rm-v202t for dav-sb100
Direct Code Entry
- Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
- Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
- Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
- With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand
I have an "naxa tv" and I really need the code for
- Turn on the component to be programmed.
- On the remote control, press and hold the S button.
- While holding the S button, press and release the POWER button
- Release the S button.
- Press and release the appropriate component button for the component being set up.
- While pointing the remote control at the component, press and release the CH + button.
- Press and release the POWER button.
NOTE: Repeat the previous two steps until the component responds. It may take 70 tries until the correct code is located.
- When the component responds, press the ENT button.
Trying to program Sony RM-V202 universal remote
Press SET and POWER button at the same time, press TV,press and release the CH+ button,then press and release the POWER button, each time you press CH+ and POWER button a code is entered. Keep trying until the TV goes Off. It may take 70 trys, when it does turn off press ENT.button to save code. hope this helps..
What is the code needed to run a visio tv with the
Vizio use the same codes that: Gateway, Tatung, Westinghouse, Viewsonic, Teac, Sampo, Sanyo
I have 5 codes for Vizio, 4 are the same that the 4 that I have for Viewsonic, so start traying those if you find them in your remote book. But I didn't find a match for the 5` code.
Good luck
