20 Most Recent
Lexerd sony ericsson Xperia X10 MINI Pro TrueVue Crystal Screen Protector Questions & Answers
Speria 10x mini touchscreen not working I can not unlock
you dropped your smartphone?
Try to manual reset your phone by the reset button, it is located in the back side under the battery cover in the left lower corner of the IMEI sticker.
If this don't work probably the touch is broken and you have to replace it.
Saluti
Damiano
How do I get my puk code for xperia
you can use puk code only for sim card not for any mob call custemer care using the same sim company and ask them for puk code they will surely give you your puk code to unlock sim
Xperia u20i
Have you tried adjusting the volume on your phone when it is not in speaker mode?
I don't know how to recive a photo being sent to me via bluetooth??
Locate and click on the "Manage Connections" icon.
Click "Bluetooth Connections."
Highlight the device you wish to connect to.
- and choose "Connect."
- Click "Yes" in the dialog box that appears when the file is sent from the other device.
Choose the location you wish to save the file to from the drop-down list that appears.
Click "Save."
I could not connect to internet using WiFi
Their Maybe A Problem With The Server You Are Using To Connect Or The Phone May Not Be Able To Connect Using Wifi But The Other Thing Is, That The Wifi Card Could Become Broken
How to get a sim network unlock pin
There can be many ways to Unlock your phone. As far as i know unlocking by codes is the simple and safe way. I will suggest the website
Unlock-Zone.com which is doing good service and they were recommended highly in the cell phone forums.
I used them to unlock my cell phone. contacted them and within 30 mins i had my unlock code and my phone was unlocked.
Hope this helps.
Hi i have forgotten my password for my googlemail,
Try using the Google account login recovery site: https://www.google.com/accounts/recovery
It should help if you forgot your username, password, or had your account hacked.
Please leave feedback if this was helpful. Thanks.
Troubleshooting stanley bs16bs
This could be due to several reasons such as a faulty battery, a problem with the charger itself, or an issue with the connection between the charger and the battery. Here are some general steps you can take to troubleshoot this issue:
Check the Battery: Ensure that the battery you're trying to charge is not faulty. If possible, try charging a different battery with the same charger to see if the problem persists.
Check the Charger: Make sure the charger is functioning properly. If you have another charger, try using it to charge the battery.
Check the Connection: Ensure that the connections between the charger and the battery are secure and clean. Any dirt or corrosion could interfere with the charging process.
Reset the Charger: Unplug the charger, wait a few moments, and then plug it back in. This can sometimes resolve minor technical issues.
https://www.manua.ls/stanley/bc15bs/manual
If unresolved, you might contact Stanley customer support.
4/18/2024 3:05:03 PM •
Cell Phones
Answered
Yesterday
