20 Most Recent
Sony CDP-CE275 5-Disc CD Changer Questions & Answers
Distorts the sound when reading most of the time.
The Op Amp in the unit are oscillating if you hear hiss and if there is distortion they could be bad. This is a job for a Technician to check out.Make sure you are NOT plugging in a CD player output into a Phone input on a receiver or amp. The CD is 1000 time too much voltage.
Static sound
Try a CD cleaning kit and follow instructions if this fails it is more cost effective to replace the CD changer than have it repaired.
On a sony cdp-ce275 5-disc
since it is a changer and not a receiver there is no volume as that is controlled by a separate amplifier.
CDP 265 5-disc player
If the disc is actually loading but won't read, try cleaning the laser lens with a cotton swab. Unplug the unit and remove the cover to access the laser. Spray a small amount of glass cleaner on the swab and gently wipe the lens of the laser assembly. Use the other end to dry it and remove excess dust. The only way you can tell if the disc is loading is to remove the top cover and observe if the disc at least loads and spins. If it does, try that procedure.
If the disc doesn't come up to the loaded position and spin (spin the disc by hand to confirm this), your gears may be out of alignment. Take the disc out, and use a screwdriver to manually turn the gear from the bottom of the unit. The gear should be visible through a small hole in the bottom toward the front of the unit. Take a slotted screwdriver and turn it until you see the laser assembly come up to the clamp that holds the disc in place. You may have to force it slightly if the gear has skipped a notch, it might "pop" as it goes past the tooth. Make sure you are turning it in the same direction as it moves when loading a disc! Once you do that, the laser should come up completely and be able to clamp the disc and read it.
Sony PMC-R35L "no disc" message
That is usually because of dirty or defetive lens.
Try first using a len cleaner ,
like the ones here.If
this does not work it will be necessary to take apart the unit and
accees the lens to clean it, or replace the lens pickup. The repair must be done by a technician.
In this case call the number listed on the owner manual to get assistance
Will not play anything.
There is a rubber belt inside the loading mechanism, you should replace it by the new one. Cleaning the optical unit can be of great help also.
If you need more info, please advice.
