20 Most Recent Sony DVP-NS501P Progressive-Scan DVD/CD Player : ** Now Your Chance Brand ** CD Player Questions & Answers
yes you can -- it will cost about $60 for the software though -- go to this site
http://www.roxio.com/enu/products/easy-vhs-to-dvd/standard/overview.html?gclid=CJCf5t3w06QCFQpV5wod1kvgIg
Sony DVP-NS501P... | Answered on Oct 15, 2010
go into the menu settings on the dvd player and see if the S-video setting is set to on, if it is set it to off.
hope this helps.
Sony DVP-NS501P... | Answered on Aug 04, 2010
HELLO
My advice to you is buy the original remote! Lots of these so-called UNIVERSAL types never have all functions so get the proper remote and set it up right!
Sony DVP-NS501P... | Answered on May 15, 2010
check wires if nothing then its broke replace
Sony DVP-NS501P... | Answered on Oct 31, 2009
Remove & re-seat the component video cables at both the TV and the DVD player.
If the problem continues, disconnect BOTH ends of the BLUE cable and the RED cable. Connect the BLUE cable to the RED jack at both the DVD and TV, and connect the RED cable to the BLUE jack ob both the TV and DVD. If the RED color comes back and the BLUE is missing, then replace the RED cable (the red cable is broken and will not pass the signal that it is connected to).
If all works, reconnect the colored cables to the corresponding colored jacks at both the TV and DVD player.
If the RED color still won't display, isolate the trouble to either the DVD player or TV by connecting the DVD to another TV w/ component jacks. If the RED is still missing, it is a problem inside the DVD player - if the RED displays, it is a problem with the TV.
Sony DVP-NS501P... | Answered on Sep 30, 2009
You need a learning remote control or check e-bay. Almost any Sony DVD remote will work. 10-20$ If you list the model # of the remote I may even have one. Hope this helps
Sony DVP-NS501P... | Answered on Aug 17, 2009
The key is having at least a Universal Remote ($10.00 or less) that will operate your brand of TV. Your TV is only looking at "stations". You need to make it see Aux-1, Aux-2, or Line In mode. BUT, another trick is to run the DVD into your VCR (if capable). Select the VCR proper "input mode" (Aux-1, Aux-2, or Line In mode) then the DVD will play through the VCR and it will play through the TV on either channel 3 or 4. Problem solved!
Sony DVP-NS501P... | Answered on Jun 27, 2009
What you have to do is unplug it and plug it back in it resets the dvd player
Sony DVP-NS501P... | Answered on Mar 16, 2009
There are several ways to connect the TV to the DVD player but you can only take advantage of the progressive scan option on your player if you use component cable. Component cable has three input jacks on it and they are colored Green, Blue, and Red. Your TV/amplifer must have component input jacks on the back of it to use this cable. If it does, then the input jacks on the back of the TV are usually labled Y, Pa, and Pr. The Y input is for the Green input jack, the Pa input is for the Blue input jack and the Pr is for the Red input jack. Once you have these plugged in you will next need to hookup the audio/vidoe cable that came with your DVD player that has a Yellow, White, and Red input jacks on it. The Yellow input jack is for Video and the White and Red are for audio. Both your TV and DVD player will have inputs for these so just match them up. If you do not have component inputs on your TV then just hook up the audio/video cable and it will work.
Sony DVP-NS501P... | Answered on Nov 15, 2008
you may have a region1 player and are trying to play a region 2 disc or vise versa or if you are playing copyed dvds are they finalized.
Sony DVP-NS501P... | Answered on Jun 05, 2008
Not too difficult. On the back on the far left are two phono sockets marked CD, you can simply get some decent RCA to RCA leads and connect them via that.
Some CD players have either an RF lead or digital output socket. Suitable leads can be connected to the digital in sockets on the Marantz.
Sony Audio... | Answered Yesterday
https://www.yoreparo.com/enlace-externo?codeHref=aHR0cHM6Ly9kcml2ZS5nb29nbGUuY29tL2ZpbGUvZC8xQTZyTW1oeWZGN1NMblNJN0NZaExZSFhERTAtczA2Wk0vdmlldz91c3A9c2hhcmluZw%3D%3D&hash=4981dcf39dad0183130fb45eed7055ba
Sony Audio... | Answered on Oct 04, 2019
Disc loader mechanism fault. Contact any service technician. The mechanism should be taken out from the set for repair, and this is a skilled work. If you wish to get some details; visit the site linked here. Pull up older posts. http://schematicscom.blogspot.com/
Hi Jose, do you have connected the card with the AM and FM antennas on your Sony HCD EC55?
If this is the case and you cannot tune in, you have problems in the tuning module
Find a specialized Sony technical service
I hope you can solve the problem
Regards Franco Dosil
Hola Jose, tienes conectado la ficha con las antenas de AM y FM en tu Sony HCD EC55?
Si es asi y no puedes sintonizar nada, tienes problemas en el modulo de sintonia
Busca un servicio tecnico especializado Sony
Espero puedas resolver el problema
Saludos Franco Dosil
https://www.manualslib.com/manual/510640/Sony-Mhc-Ec55.html
Sony Audio... | Answered on Oct 02, 2019
Sony DVP-NS501P Progressive-Scan DVD/CD Player : ** Now Your Chance Brand ** CD Player Logo
20 questions posted
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Ekse
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Audio Players & Recorders
Most Popular Question
movie no red color only green yellow
  • Audio Players & Recorders
