Check with your company, maybe you have less things than you think. Check how much data you get, how many minutes you get, and any specifics about your plan. Also, make sure you are not purchasing apps, music or any other media that is causing you bill to increase.
Hi free unlocking service is only available for old mobile model. So better you can go for paid unlocking service. I would suggest this site Unlock-Zone.com here you can get the code and unlock your mobile. To get the code you have to mentioned which country is locked now,network provider and imei number. Then they send unlock code through email.
Unlock-Zone.com
You can get the unique nck code(unlock code) for yout T-Mobile Tap from Classicunlocking.com and remove the restriction from the particular network by specifying the country and network to which the mobile is locked to.You will receive the unlock code along with free unlock instructions.
You'll need to purchase an unlock code.You will probably find a number of companies via google a I have used a couple, which I'm not sure I'm allowed to post here so I recommend you visit Unlock-Zone.com, which is nearly perfect and they were recommended highly in the cell phone forums.Click the unlock your phone and select the mobile phone, current service provider to get the available unlocking service which ranges from $5 to about $25, depending on the model of phone you have.
The process of unlocking a phone is actually quite simple, and doesn't require any technical knowledge. There are three accepted methods for accomplishing the unlocking. For some phones, you just have to enter a numeric code into the phone. For a fee, some service providers will even give you the unlock code for your phone. There are also third party companies that provide cell phone unlock codes for a fee that ranges from $5 to about $25, depending on the model of phone you have. I recommend the site Unlock-Zone.com which is nearly perfect and they were recommended highly in the cell phone forums. I used them to unlock my cell phone. contacted them and within 30 mins i had my unlock code and my phone was unlocked.Hope this helps.
There are two types of lock.
A consumer set passcode lock. That is easy, you just do a hard reset, which deletes all the data and reloads the software as a clean install.
Or it is locked with a PUK Lock aka a SIM Lock.
https://www.fixya.com/support/r26056685-phone_asking_puk_code
You can take emergency action to avoid the data losing or reduce the data lost to the least as follows: 1) Get out your phone from the water ASAP, and remove and battery and take out the SIM card to reduce the loss or damage on the device; 2) Don't move or shake the phone frequently, so that the water will not run around your mobile phone inside; 3) Wrap the device with cloth or handkerchief for a few minutes, and then turn off your phone, and place it into a jar or a bag filled with rice for a couple of days. But if you find something important are lost,like contacts, don't worry, you can ask for help from MobiKin Doctor for Android (Windows/Mac). Step 1: No matter which brand of your Android device is, just connect your device to the computer with USB cable Step 2: Files on your Android have been categorized and displayed on the interface. Tick off these data types you want to recover back and click "Start" button to let the Android data recovery program scan your Huawei P10. Step 3: When the scan is finished, you can preview the scanned out data, find and mark the data you wish to restore and hit "Recover" button to save them on your personal computer without losing. It's very easy.Try it.Hope it could help you. A YouTube Guide for you: Read More: How to Recover Data from Water Damaged Android Phone or Tablet How to Use MobiKin Doctor for Android
If you want to unlock a device that's locked to our network, you'll need a Network Unlock Code (NUC). If you already have one, you can unlock your phone.
There could be several reasons why your Huawei MediaPad T3 7 keeps shutting off and turning back on. Here are a few troubleshooting steps you can try:
Charge the device fully: It's possible that the device's battery is low, causing it to shut off and turn back on. Try charging the device fully before turning it on.
Boot into Safe Mode: Booting into safe mode can help you determine if the problem is caused by a third-party app. To boot into safe mode, press and hold the power button until you see the Huawei logo. Then, press and hold the Volume Down button until the device boots into safe mode.
Perform a factory reset: If the problem persists, you may need to perform a factory reset to eliminate any software issues. Before doing so, be sure to backup your data to avoid losing it. To perform a factory reset, go to Settings > System > Reset > Factory data reset.
Contact Huawei support: If the above steps do not solve the problem, it may be a hardware issue. In this case, you should contact Huawei support or bring the device to a certified repair center for further assistance.
Unfortunately it sounds like the phone is stolen and has been SIM Locked by the Telco that still owns it under an undischarged contract, or if bought outright, the owner has asked the Telco to lock it so no one else will get the benefit of their loss. I bet the seller will suddenly vanish and you won't be able to contact them. It is a $1,200 phone!
This explains
https://www.fixya.com/support/r26056685-phone_asking_puk_codehttps://www.google.com/search?q=Huawei+Nova+5T
In a photo editor like photo shop. Be aware even after enlarging a photo, it will not have more info. Small pictures have little info, and will be blurred when enlarged.
