20 Most Recent
Advantech IPC-610-H (IPC610HP72456) PC Desktop Questions & Answers
The IPC 610 PC got
Bluntly, this is unresolvable in a forum like this. Try pushing the F10 or the ALT and F10 together when you first boot and see if you can get to BIOS prompt. If you can, see if you can see all the devices. I'll assume it's a windows PC. Try booting with the F8 key pushed which will take you to the advanced boot options. If you get that far, go find a windows expert to take you further.
If you can't even get to the BIOS and you don't get any fault codes (beeps) from the MB, it may be the MB or even the BIOS ROM itself.
If the HDD light is a steady blink, it could be it has faulted. If it randomly blinks, it likely a driver failure and you try the F8 option.
12/29/2017 12:32:55 AM •
Advantech...
Answered
on Dec 29, 2017
Install wireless card wireless network interface controller
The wireless Adapter Card should have come with instructions....
If not, then it is fairly simple if you have the 'driver' CD.
1. Load the driver CD and follow the Instructions to load the drivers.
2. Shut-down the PC.
3. With the Power to the PC OFF, UN-plug the Power-cord to the PC.
4. Insert the Wireless Card into an expansion slot on the motherboard that fits the type of Card you have....DO NOT attempt to 'force' it into a different-slot.
5. Close it up and Plugg it in and power it on.
Note: SOME wireless cards require that the Card be installed BEFORE the drivers.
for more specific details, the make/model of the wireless card is needed.
11/13/2014 8:42:11 AM •
Advantech...
Answered
on Nov 13, 2014
How do i remove the hard drive?
carefully remove the two screws on the back, left side of your cabinet.
now you can see the hard disk placed on a rail. unplug the power and data cable connected to the hard disk (4pin power and 40pin data). now unscrew the hard disk from the rail and slide the hard disk out side from the rail.....
9/1/2010 1:52:47 PM •
Advantech...
Answered
on Sep 01, 2010
I can't hear the voice of songs during playing mus...
You might have muted the sound. So to fix your problem follow the easy steps
- Click start
- Go to control panel
- Click "sound,speech and audio.devices"
- Click the second option "Sound and audio devices"
- If there is a tick on mute undo it then Click on OK and then click on "Apply"
Your problem would be fixed
5/24/2010 3:49:55 AM •
Advantech...
Answered
on May 24, 2010
I want the drivers voor playing music ....can you
This is a server, not a standard PC. This type of system rarely comes with a sound card installed on it. I would suggest finding out if it is even capable of having a sound card on it, and if it does, you would have to tell me what kind of sound card it is.
Good Luck,
NOLA Tech
1/29/2010 3:08:08 PM •
Advantech...
Answered
on Jan 29, 2010
Ppc 153t
if it is damaged, then it will need to be replaced. You will have to determine whether or not it is an IDE or a SATA cable; although if you REALLY have it connected to a CD-ROM, then it is an IDE cable.
If you have local PC repair shops in your city, give them a call. They will have perfectly good 'used' ones they likely will be glad to give away....I know I do ! lol
If you do not, then you can get them online cheap here :
StarTech Model IDE66 18 Ultra ATA 66 100 133 80 wire IDE Cable StarTech...
11/13/2014 8:33:52 AM •
Advantech...
Answered
on Nov 13, 2014
Ribbon to hard are bad
Hi
Do you need the 40 wire connector ribbon cables or do you need SATA ribbon cables to connect the hard drive to the motherboard?
3/21/2009 9:21:38 PM •
Advantech...
Answered
on Mar 21, 2009
Mother board driver
You can try Nodevice.com
or type free download motherboard drivers in google search
9/28/2008 4:39:05 PM •
Advantech...
Answered
on Sep 28, 2008
