20 Most Recent Sony DAV-FC7 System Questions & Answers
Sony DAV-FC7 won't power on. I bought it new and have only had it for about 2 years.
I suspect you might have a power failure caused by an internal fuse. Fuses rarely just go on their own, so it might be caused by an overload, generally caused by a faulty output device. If you have any knowledge to repair one or no someone who has you can or they can look around inside. Otherwise it's off to the repair shop with it. Unless you have a five year warranty on it or have paid for extra cover, then you will be liable for the full cost of the repair. If you have a five year cover or extended plan, contact the manufactory or the service plan provider. But do NOT open the unit yourself.
9/26/2016 5:57:51 PM • Sony DAV-FC7... • Answered on Sep 26, 2016
manual
manual
4answers
High-pitched sound when using surround sound
THANK YOU Guest (4/10/08)!!!
That was exactly what I needed! We have had our system for 4.5 years and suddenly, the FM feedback on everything, but DVD and Radio! Your fix helped. Once I set all my presets (at least the current one) to a clear station, the feedback stopped. Hallelujah!! We can enjoy this piece of junk once again! ;)
Amanda - San Antonio, TX
6/23/2013 6:46:11 PM • Sony DAV-FC7... • Answered on Jun 23, 2013
0answers
Unit will not read CD's.
This is a common problem with playing copied CD's. It burns out the readers on less expensive units.
1/20/2013 1:52:11 AM • Sony DAV-FC7... • Answered on Jan 20, 2013
2answers
Sony AV System DAV-FC7 cannot turn on
Now the solution (rather, a workaround) for this problem is power off the main supply (or remove the plug from the electrical outlet) and then plug it again. From now, on do not power off the unit. If you have to, then you need to perform the work around again.
-Sathish
1/20/2011 3:19:53 AM • Sony DAV-FC7... • Answered on Jan 20, 2011
My system power is intermittent. Won't turn on
Make sure all cords are properly connected if so then their might be a problem with the wiring... try moving the wiring up and down, and see if the power turns on when you do that.....
1/9/2011 8:50:16 PM • Sony DAV-FC7... • Answered on Jan 09, 2011
I have a Sony DAV-FC7
you will need a specialist repair man their is a problem with the switch but a micro chip recieves the order from the switch and then tells a transistor to switch power on ,its a bit beyond myself this problem but the sony agent will change a part and it doesnt cost a lot .
12/29/2010 10:09:59 PM • Sony DAV-FC7... • Answered on Dec 29, 2010
Can i watch regular tv and use the dav-fc7 as
just run the "line audio" not your speaker audio out from your tv to the aux or dv/cd input...
on your dav-fc7 it will sound great! just turn the tv audio sound down at the set.
12/3/2010 1:55:08 AM • Sony DAV-FC7... • Answered on Dec 03, 2010
Goes into Standby, have to unplug to reset
You have to lift one pin of the mircoprocessor and solder in a resistor from that pin to a smd cap on the main board. This does require a lot of skill as if when lifting the pin on the mircoprocessor you break that pin.You then have to replace the mircoprocessor. I have done this mod to over 30 unit and i still every once in a while break that pin.Of course my expense now.I can give you value of resistor and points of soldering if you email me as this is not common knowledge.
4/22/2010 1:45:09 PM • Sony DAV-FC7... • Answered on Apr 22, 2010
Moved device, now not able to change sound fields,
Unit requires Reset of speaker settings, please perform following procedure:
1- Press AMP Menu repeatedly on remote until Customize appears in front display.
2- Select MEMO CLR N by up/down arrow keys.
3- Set MEMO CLR Y by left/right arrow keys and press ENTER
4- Unit will ask confirmation, press ENTER, you will see ALL CLEAR on front display, this will reset speaker settings to default and problem will be solved.
Let me know if you have additional question.
Thanks.
4/18/2010 5:17:54 PM • Sony DAV-FC7... • Answered on Apr 18, 2010
Will not turn on
There is a mod that has to be done to prevent this problem which the average person can not due as you have to put a resistor from one spot to the another spot to a pin on the microprocessor. A shop that repairs Sony product will be aware of this mod.Usally takes about a half of an hour and a 10 cent part is required. repair will run around $100.00 if taken to a shop.
4/17/2010 1:26:41 AM • Sony DAV-FC7... • Answered on Apr 17, 2010
2answers
Won't play disc
Unit is old enough that the laser pickup may be worn out. Not an uncommon problem with older disc players. You may try to obtain the laser pickup yourself at someplace like MCM eletctronics
8/19/2009 2:25:08 PM • Sony DAV-FC7... • Answered on Aug 19, 2009
Sony DAV-FC7 System Logo
Popular Tags
34 questions posted
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
ZJ Limited
ZJ Limited
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Audio Players & Recorders
Most Popular Question
goes into standby unplug reset
  • Audio Players & Recorders
