20 Most Recent
Sony LBT-XGR6 CD Shelf System Questions & Answers
PROTECT PUSH POWER
My Sony audio set keeps saying push power protect and the set freezes what should i do? Please help me solve this problem.
SONY LBT-XGR6 COMPACT STEREO
Sounds like your protection circuit has been activated, which usually means that you have some blown output transistors. Good luck.
MY SONY STERIO KEEPS FLASHING
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections at the speaker as another possible root cause for intermittent shutdown.
Power protection
Check for loose speaker connections at the speaker as a root cause for intermittent shutdown.
When its turn on it
Overloads can be from excessive periods of high output and shorts would be wiring issues or a speaker blowing up.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced hands-on tech.
When I turn on my
the ic was burned out it happens when you put the volume too loud for a long time.
I have an 2002 LBT-XGR6
Hi ZDun,
My name is Mike, I'm here to help. You are my eyes and ears on this. So I'm going to ask some questions, you comment back with the answers. Some may seem common sense but I have to ask anyway. Ready?
OK. So we are clear, the speakers are currently Not working. No sound comes out of any of them whether it is set to Radio, CD, whatever?
If so, Might be able to believe a single piece of wire to have a fault. BUt all of them? Nah.
I've got to lean toward a very easy cause. Check the panel for a speaker select or mute button.
- If there is a mute button, is it off?
- Does the device have more than one set of speaker outputs? IF so, how are they selected? Which is selected?
- Is the volume up? (I am so sorry to ask, but you would be surprised)
- Is there a set of headphone plugged in?
- If you have a set, plug them in, do they play?
Please comment back with you answers and observations
Mike
Its a 2001 stereo system
Hi
Thanks for using FixYa. Please check if the wires are not cut or loose. You mean no sound is coming when you try and play an Audio CD. If yes the use a Lens cleaner CD to clean the Lens of the CD player. If that doesn't resolve your issue then try and reset your player by turning it off and unplugging it from the wall socket. Also check if you are getting any sound from the Headphone jack. Also check if there is no shorted speaker wire/connections.
If these steps doesn't resolve your issue then it is due to Digital Audio processor chip that has open connections.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Protect push power
hi, everytime i switch on my sony hi fi it the display screen says protect push power. It won't let me do anything not even put cd's in. If you could help that would be very much appreciated.
Connecting SONY TA-D505 amplifier LBT-D505
Hi David, do you want to connect the ST-D505 tuner to the TA-D505 amplifier?
You just have to connect an audio cable of two RCA (red and white) from the audio output L and R of the tuner ST-D505 to the input of Tuner in the amplifier TA-D505
Remember to connect the FM antennas and the AM Antenna Loop on the ST-D505 tuner
To listen to it, you have to select Tuner on the TA-D505 and enjoy the favorite radio stations
I hope you have my comments
Greetings Franco Dosil
Hola David, quieres conectar el sintonizador ST-D505 al amplificador TA-D505?
Simplemente tienes que conectar un cable de audio de dos RCA(rojo y blanco) desde la salida de audio L y R del sintonizador ST-D505 a la entrada de Tuner en el amplificador TA-D505
Recuerda conectar las antenas de FM y la Loop Antena de AM en el sintonizador ST-D505
Para poder escucharlo, tienes que seleccionar Tuner en el TA-D505 y disfrutaras de las estaciones de radio preferidas
Espero que te sirvan mis comentarios
Saludos Franco Dosil
https://elektrotanya.com/sony_lbt-d505_d505cd_d505cdm_d505m.pdf/download.html
