20 Most Recent Sony STR-DE675 Receiver Questions & Answers
0answers
How do I connect my turntable to a str de-675 receiver
Take 2 rca wires a white one and a red one. On the back of the receiver, find a source you are not using( md/tape or aux ) connect red to red, white to white Turn on receiver and on the front, push related button( aux ). This should work. Good luck
2/11/2015 8:54:20 PM • Sony STR-DE675... • Answered on Feb 11, 2015
2answers
How do you fix relays?
I would check the solder connections on the bottom. Relays are notorious for breaking the solder connections thus becoming intermittent
10/29/2014 3:50:31 PM • Sony STR-DE675... • Answered on Oct 29, 2014
Str-de685 WHEN I POWERED I HEARD A CLICK BUT
There is a relay on the power supply circuit board that might be faulty or has bad solder connections. If this relay does not work, power is not applied and everything is "dead". I had to re-solder the speaker relays on my STR-DE675 because they had cracked solder joints which made them work intermittently. It's possible that the power relay is what is causing your problems. If it has bad solder joints it might click, but power might not be able to pass trough the joints. Does it still click when you turn it on or did it only do this once?
7/20/2014 3:43:44 PM • Sony STR-DE675... • Answered on Jul 20, 2014
2answers
Headphone jack on old sony amp silent
Maybe there could be a loose wire inside try taking it apart and searching for any thing loose do you have a warranty on it
5/13/2014 6:55:39 PM • Sony STR-DE675... • Answered on May 13, 2014
Need remote control programming codes
I assume you have purchase a universal remote control...if the programming codes for your Sony STR-DE675 receiver is not listed in the remotes code guide, then you purchased the wrong type universal remote. Make sure you get a universal that does stereo equipment or check eBay for a reasonable price on the original.
1/8/2014 3:54:44 AM • Sony STR-DE675... • Answered on Jan 08, 2014
ME MARCA PROTEC
asegurate que los cables de las bocinas no se hayan juntado si fue asi tendras que canviar el circuito integrado de sonido.por eso se proteje.
12/17/2013 5:02:40 AM • Sony STR-DE675... • Answered on Dec 17, 2013
0answers
Sony STR-DE675 Receiver Logo
58 questions posted
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
ZJ Limited
ZJ Limited
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Audio Players & Recorders
Most Popular Question
fix relays
  • Audio Players & Recorders
