20 Most Recent Sony STR-DE435 Receiver Questions & Answers
6answers
Protector flashing
This happens to me too... I have a DTR 5.4... Worked well for a couple of years... Now it is shutting off when I have the volume up too high... Although, sometime it just does it at random.... Very annoying...
2/2/2017 4:30:07 PM • Sony STR-DE435... • Answered on Feb 02, 2017
How can I plug my
Least expensive way is thru a 1/8th" mini to RCA adapter into any of the Sony's audio inputs. If you want "Video" as well, that's another story. You would have to check with "Apple" to see if an adapter is available. No "Dock" port on the receiver. Hope this helps.
7/2/2011 6:56:51 PM • Sony STR-DE435... • Answered on Jul 02, 2011
The protector light comes on
The receiver has a short in the audio output stage in at least one channel, the parts must be replaced to bring it back up to normal operation.
3/10/2011 6:19:40 PM • Sony STR-DE435... • Answered on Mar 10, 2011
My screen on my interainment
hello almbom
looks like the unit is going to self protect caused from malfunction of the amplification sector. mainly happens if speaker cables shorten or when speakers used with very low impedance, feel free to cantact for further help
regards
2/20/2011 11:11:16 PM • Sony STR-DE435... • Answered on Feb 20, 2011
Str de 435
Relay click and Protect display indicates that receiver got problem in output amplifier section and most probably output chips got defective. This kind of problem is not user level repair and local repair shop will help you to get it fixed.
Thanks.
10/15/2010 10:20:07 PM • Sony STR-DE435... • Answered on Oct 15, 2010
Can I hook up a photo turntable to a sony str-de435 receiver?
If your turntable has an amplified output, go ahead and plug it in to the aux port. If not, you won't be able to use it with your receiver properly. Look on the back (or front) of your turntable for a knob labeled "level" or "volume", and that will determine if it's amplified or not. Good luck, I hope this helps!
10/19/2009 12:30:43 AM • Sony STR-DE435... • Answered on Oct 19, 2009
Protector is flashing and nothing can be done to
you have defective audio output circuit, like the other ones y might be the transistors or the drivers IC's (integrated circuit ) you need some repair skills to fix this problem.
good luck
6/18/2009 9:53:23 AM • Sony STR-DE435... • Answered on Jun 18, 2009
Sony str-DE435 Flash Protector
this is not a reset problem, you have a defective audio output, is either the outputs transistors or the drivers IC's ( integrated circuit) and sometimes if you are lucky is just loose connections on the drivers IC;s.
good luck
6/18/2009 9:50:24 AM • Sony STR-DE435... • Answered on Jun 18, 2009
Flashing protector
This usually means an output transistor is shorted and the amp is protecting itself. There are usually 2 8 amp fuses GMA type (glass tube) that are located near the large transformer on the main board that also get blown. You can try the fuses and see if it fixes it (10% of the time it will). If they blow again, it will be one or more output transistors are shorted, and the unit will need professional repair.
6/13/2009 8:32:25 AM • Sony STR-DE435... • Answered on Jun 13, 2009
Protet mode is a special diagnostic mode that starts when a fault is detected.
When in protection mode the unit is prevented from starting by protection circuit, so to prevent further damage.
Check the speakers and speakers wiring, a contact in speaker wires, or faulty speakers can send the unit in protection.
Try unplugging power cable for one hour or so. then connect cable back and see if you get rid of protect state. Sometimes accumulation of electrostatic charges inside circuit capacitors can kick in protect mode. In that case unplugging the unit from main for some times can get rid of electrostatic charges, and reset circuits by draining power completely.
If that was the problem, you will not get Protect when plugging back power cable.
If you do all the above and still get Protect, then there is a real fault.
In that case the unit may be disassembled and tested to find the fault.
If that is the case I suggest contacting the manufacturer at the number listed on the owners manual, or asking a quote on repair to a local technician.
5/29/2009 1:03:04 PM • Sony STR-DE435... • Answered on May 29, 2009
0answers
STR DE435 PROTECTOR STR DE435
I have the same problemwith mine. the protector sign is on- I do not know why- and do not know what to do about it. Let meknow if you do or if you get assistance and I will do the same. My e-mail address is [email protected]
2/28/2008 5:13:32 AM • Sony STR-DE435... • Answered on Feb 28, 2008
How do I preset a second AM station on a Sony SRF-M97 Walkman
It looks like the manual knows, and you can have 5 AM station presets and 15 FM. https://www.google.com/search?q=preset+a+second+AM+station+on+a+Sony+SRF-M97+Walkman ..
4/18/2024 5:09:49 AM • Sony Audio... • Answered 19 hours ago
Sony PS-FL7 direct drive turntable. When start button is pressed it illuminates but turntable won't rotate. All other functions work as they should.
'Direct Drive' appears to mean something different to Sony unless the belt is for another function. https://lptunes.com/products/sony-ps-fl7-ii-ps-fl7-ii-psfl7-ii-turntable-tonearm-belt-replacement Service Manual
Sony PS-FL7 Stereo Turntable System Manual
Vinyl Engine https://www.vinylengine.com > library > sony > ps-fl7 Sony PS-FL7 owners manual, service manuals and schematics are for reference only and the Vinyl Engine bears no responsibility for errors or other inaccuracies. "); background-repeat: repeat-x; display: inline-block; overflow: hidden; position: relative; background-size: 14px 11.4px; height: 11.4px; width: 68px;">"); background-repeat: repeat-x; display: block; background-size: 14px 11.4px; height: 11.4px; width: calc(56px);"> Rating: 8/10 · ‎ 4 reviews
SONY PS-FL7 service manuals download
NoDevice https://www.nodevice.com > ... > Vinyl Players > SONY SONY PS-FL7 service manual (Vinyl Players) in PDF format will help to repair SONY PS-FL7, find errors and restore the device's functionality. ..
4/6/2024 7:54:41 PM • Sony Audio... • Answered on Apr 06, 2024
Sony STR-DE435 Receiver Logo
24 questions posted
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
ZJ Limited
ZJ Limited
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Audio Players & Recorders
Most Popular Question
protector flashing
  • Audio Players & Recorders
