20 Most Recent
Sylvania DVR90VE DVD Recorder/VCR Questions & Answers
FIRMWARE UPDATE
Sorry to hear about your problem. I do own this model too. I have not gotten the update myself. I just started using the dvd recorder.I bought a pack of dvds (Ativa) and now I need to return them, they are not supported by this dvd player. I called the 800 number and they told me some of the dvd brands it supports: JVC, TDK, Memorex, Maxell and Sony. I know Sony works, because I used them before. I also read "Vibratim" brand from Sam's Club works.
How to record
Be sure you have first set the clock correctly. After setting timer recorder time, channel, speed etc. hit enter to highlight the setting to be sure you have it. Press setup to put you back to tv screen. Then press t-Set button on remote. Unit will automatically shut off and there will be an amber symbol on the unit lcd along with the time. This indicated the unit is in the timer mode. It will automatically turn on and record the program at the set time.
How do I get a instruction manual for this
You can download and print the instruction manual in PDF format by clicking this
link.
Please note: Adobe PDF Reader is required to view this manual.
Click here to download the latest version of Adobe Reader.
Hope this solves your problem. Thanks for using
FixYa.
Machine keeps saying
Hi
Thanks for using
FixYa. Please check that the DVDs are
not scratched. Now run a lens cleaning DVD.
If that does not work then you have to open the unit and clean the lens with a
Q-tip dipped in alcohol. This is only recommended when the unit is not under
warranty and you have some expertise in the field. If still
the issue is not resolved then the lens is required to be replaced. Please do accept the solution if the
issue is resolved or post a comment for further assistance.
Thanks
Rylee
Como le ago para programar los canales en la
Necesitas poner el cable de señal en el combo y de ahi a la television para que puedan grabarse en el combo ya que es el quien va arecepcionar la señal que quieres grabar no la tv la tv solo va a estar en modo video o en el canal 3
