20 Most Recent
Dell Inspiron 13R (N3010), 14R (N4010), and 17R (N7010) Laptop... Questions & Answers
I have a dell inspiron
Hello
Check your system with external speakers, if it gives same problem its mean that the audio drivers od the system gone corrupt, needs re-installation,
if the system gives the correct sound, means that the speakers gone damaged, need repair/replacement, you can do by your self if you are technical enough otherwise you need technical assistance from Dell Support
Good Luck
Web cam is not working. it shows plug in a
There are two possible issues:1. May be your wiring is disturbed and you need to take it to the technician.2. And the most possible issue is that you need to upgrade the drivers of it.
I want to reformat my
You need to get a windows xp to be able to format your system very well.
good luck.
CANNOT GET INNTERNET EXPLORER
if know some one has internet go to their house and download firefox or google chrome now google one of the options and proceed to download and press save file to you will have install firefox or google chrome you must have a usb port i hope it work ;)
Several times a day my
in that case it's either your (RAM) memory is low related to the programs that you've installed on your computer...
Try this steps to boost your (RAM) memory
Run the CMD
Then type SYSEDIT.EXE all caps
then close the two balnk window then click the fourth window
fin (enh) it has a number joining the enh press enter in front of the enh
then type Irq14=4090
then saved it after that restart your computer..... i hope that i solved your problem
How do you disable
Hi There,
In Windows 7 proceed as follows: (Click each one in order)
1. Start
2. Control Panel
3. Hardware and Sound
4. Mouse
5. Device Settings Tab
6. Choose touchpad from menu
7. Click Disable
To undo above, repeat the steps and click Enable
Regards,
Selk
How to disable the dell
If you want to permanently disable it, you can go to device manager and disable the driver. You can enable it if you ever want to use it again.
Can I get a external
Hi
Yes you can get an external modem for your inspiron. Most external modem devices can be plugged in using the USB ports in your laptop.Thanks
I recently bought a Dell Inspiron N3010 in
driver or hardware problem if it is happening when using the web cam and mic then thats a good place to start update the divers for them and see if it takes care of the problem
I want to know about some adventures video games?
Check out Big Fish Games. It is a subscription service but they have all types of games including adventure and hidden object. You can also tryp Pogo since they have both a fee and subscription service. Last, but not least, you can try one of your local computer stores or the electronics section of "big box" stores like Target, Walmart, Kmart, etc.
