20 Most Recent Sylvania 6719DC 19 in. TV/VCR/DVD Combo Questions & Answers
My child pushed buttons on remote and now I only get PG14 channels. How do I allow it to recieve all my cable channels?
check that the tv /receiver is not in favourites mode, there may be an option to sort channels in the channel list...try there. If you cannot fine the corrective try resetting to default and retuning from scratch. There may be an option fo isolate the control functionality so that others cannot mess about with the settings, it may need a passcode to be set, try that after correcting the issue
8/1/2015 12:56:10 AM • Sylvania 6719DC... • Answered on Aug 01, 2015
My dvd is not working on the a superscan tv/vcr/dvd combo. Can i connect an external dvd player up to the tv?
Yes if you have a scart socket on the back
8/7/2014 11:03:09 PM • Sylvania 6719DC... • Answered on Aug 07, 2014
My televison talks in english one program then the
You may want to check that you are not listening to the secondary audio program (SAP). I am not sure how to check this on your TV, but I would start by poking around the menu of the TV in the audio section if there is one.
10/14/2013 9:46:24 PM • Sylvania 6719DC... • Answered on Oct 14, 2013
Codes for criag dvd player
287,281,284,286,222,000 are the codes to check. If you wish to get more details, check this site. Pull up older posts there. Setup code list and setup proceedings to many popular brand remote controls are given. Two digit, three digit, four digit and five digit setup code list to different models remote controls are given. If you search the site in Timeslide option, which can be selected from the drop down list at the top left of the display window, it will be easy to locate the related post. You can also do a search by type in the brand name and model number to your device into its search box at the top right of display window.
4/29/2013 10:43:14 AM • Sylvania 6719DC... • Answered on Apr 29, 2013
3answers
What is sap
SAP is an alternate audio program usually seen in markets with different languages. The most common is for a Spanish broadcast of an English program. It is also used to provide audio descriptions of programming for the blind. There should be a menu option under Audio to turn this on and off.
Dan
10/13/2012 5:40:47 AM • Sylvania 6719DC... • Answered on Oct 13, 2012
How do I set the VCR Timer?
with the original remote via the set's main menu.
7/17/2012 8:30:49 PM • Sylvania 6719DC... • Answered on Jul 17, 2012
I have an old tv i can hear fios on auxilary channel but no picture
If a 19 inch as indicated here maybe time to buy another set
6/12/2012 5:45:05 PM • Sylvania 6719DC... • Answered on Jun 12, 2012
How to eject dvd
Someone needs to look inside to see if something got inside and is stopping the mechanism from working---I have even seen a few which someone had managed to get 2 discs in at same time.If the mechanism is damaged it may not be worth repair as the DVD portion (if even available) costs too much.
4/1/2012 6:58:49 PM • Sylvania 6719DC... • Answered on Apr 01, 2012
Sylvania tv/vcr/dvd keeps going from channel 3 to AUX
Hi my name is Mike Houston of DISH Network, with the TVswitching between channel 3 and AUX there are some things to check to resolvethe issue. You will want to make sure all connections are hand tight from thereceiver to the TV and to the wall. After all connections are hand tight checkto see if the channels are still going back and fourth. If it still persiststry changing the remote address, I will send a link that better explains thissetup; http://www.dishnetwork.com/SupportSection/remote-setup
11/29/2011 6:29:42 PM • Sylvania 6719DC... • Answered on Nov 29, 2011
How do you run channel
HI,
To auto preset channels do the following procedure.
1. Press the SETUP button on the remote.
2. Using UP/DOWN arrow Select CHANNEL SET UP and press the RIGHT arrow to enter to channel preset
3. Using UP/DOWN arrow select AUTO PRESET and press the RIGHT arrow to start the auto scan.
Wait till The tuner scans and memorizes all the active channels in your area.
ok
9/10/2011 2:38:58 PM • Sylvania 6719DC... • Answered on Sep 10, 2011
The remote control stopped working.
press button and face it to any mobile camera like nokia 6680 or htc touch.if light come out then its not your remote problem its you tv infrared sensor problem.
6/12/2011 7:40:53 PM • Sylvania 6719DC... • Answered on Jun 12, 2011
Sound on my Sylvania 6719DF 19in dvd/vcr combo tv
que I.c de sonido tiene, se probaron las bocinas
6/9/2011 8:20:35 PM • Sylvania 6719DC... • Answered on Jun 09, 2011
Sylvania 6719DC 19 in. TV/VCR/DVD Combo Logo
63 questions posted
Top Sylvania Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sylvania Televison & Video
Most Popular Question
program circuit
  • Televison & Video
