20 Most Recent
Uniden Nascar BC-92T Scanner Questions & Answers
How to reprogram uniden nascar
The best programming instructions for your scanner are in the factory manual that you can download and print here:
http://www.uniden.com/pdf/BC92XLTom.pdf
For a comprehensive database of active frequencies in your area, and a lot of other useful scanning information, visit:
www.RadioReference.com
Bill B.
Listening in since the 60's
Im going on a trip and want to listen to each
Your best bet is to run service searches as you travel. See page 34 of your operating manual for specifics on how to do this.
You can also pre-program frequencies for the areas that you'll be passing through. For a comprehensive database of active frequencies by location, visit:
Need the manual for your scanner? you can download and print it here:
Bill B
No book need to put in codes
You can download and print the manual for your scanner here:
For a comprehensive database of active frequencies (they're not codes) in your area, and a lot of other useful scanning information, visit:
Bill B
HOW TO PUT CODES IN SCANNER
To enter a known frequency into your scanner:
- Power the scanner ON
- Press HOLD to stop scanning.
- Enter the number of the channel that you wish to program.
- Pres the FUNC and PGM keys.
- Enter the frequency, including decimal point.
- Press E to enter the information into memory.
For more information on programming and operating your scanner, you can download/print the operating manual here:
For a comprehensive database of active frequencies in your area, visit:
Bill B
How do iclear to reset
Resetting the scanner automatically clears all frequencies from memory and restores the unit to original factory settings. To RESET your scanner:
- Power the scanner OFF.
- Press and hold the 2, 9, and HOLD keys and power the scanner ON.
- The word CLEAr will appear after about 3 seconds, indicating that the scanner is ready to accept new programming.
Need the manual? You can download/print it here:
Bill B
How to setup manual scanner
To manually enter a known frequency:
- Power the scanner ON.
- Enter the channel number that you wish to program.
- Press FUNC then PGM (the channel number will display).
- Enter the frequency, including decimal point (e.g., 156.065).
- Press E to store the frequency in memory.
Need the manual for your scanner? You can download/print it here:
Bill B
How to tell what the buttons do?
The HOLD key lets you freeze the scanner on an active channel. For instance, if the scanner stops on channel 3, and there's a lot of action there. you can press HOLD to lock the scanner on that channel until you press the SCAN key. Repeatedly pressing the HOLD key will manually advance the selected channel.
SCAN releases a HOLD asnd will also take the unit out of PROGRAM or SEARCH modes and start it scanning the frequencies that you've programmed.
FUNCTION selects the secondary (lower) function of a key. For example, pressing FUNCTION and then the E (ENTER) key will switch the scanner to Pgm (Programming) mode - which lets you enter and store frequencies into the unit's memory so that you can scan them later.
All keyboard functions are explained in detail in the scanner operating manual, which you can download/print here:
For a comprehensive database of active frequencies in your area, along with a lot of other useful scanning information, visit:
Bill B
Press Manual,enter the channel, press Manual,enter the frequency you want including the decimal point,press E. If you make a mistake, press CLR twice to erase. Get the frequency,s for your state at, RadioFreq.com or RadioReference.com hope this helps..
I can not get any police on my scanner at all
Find the frequency you want at Radiofreq.com or RadioReference.com To program your scanner,press manual,enter the channel,press manual,enter the frequency including the decimal point,press E. If you make a mistake,press CLR to erase
Need to know how to get the weather on my hand
HERE ARE THE WEATHER FREQUENCIES TO PUT THE WEATHER ON YOUR SCANNER
1:162.5500
2:162.4000
3:162.4750
4:162.4250
5:162.4500
6:162.5000
7:162.5250
THESE WILL COVER ALL THE NATIONS WEATHER CHANNELS, HAVE TO SEE WHICH ONE WORK'S IN YOUR AREA.
Cant get weather on hand held scanner
The 92 does not have a separate/dedicated weather band feature, but you can program individual NOAA frequencies into it. Weather broadcast frequencies are: 162.400 MHz : 162.425 MHz : 162.450 MHz : 162.475 MHz : 162.500 MHz : 162.525 MHz : 162.550 MHz.
D104-M6B WIRING FOR A UNIDEN 880 RADIO DIGRAM
Here is the wiring diagram for connecting a D104-M6B microphone to a Uniden 880 radio:
- Shield: Connect to pin 1 of the microphone jack on the radio
- White: Connect to pin 2 of the microphone jack on the radio
- Red: Connect to pin 3 of the microphone jack on the radio
- Black: Connect to pin 4 of the microphone jack on the radio
It's important to note that not all Uniden 880 radios are wired the same way. If you're unsure about the wiring on your specific radio, it's best to consult the manual or contact Uniden customer support for assistance.
