20 Most Recent
Uniden BC80XLT Handheld Scanner Questions & Answers
Help programing a realistic pro
- Hi, here is the users manual http://www.racingelectronics.com/files/bc80manual.pdf Page 14 tells you how to program your scanner. You have to throw at least one frequency in the scanner before it will receive anything. I can get you some for your area with a state and city.
- As for programming follow these steps.
- Press the manual button.
- Now pick what channel you will enter a frequency on by pressing on the number key pad.
- Now press the manual button again
- Now enter the frequency you want to program.
- Now press the "E" button to enter it.
- That's it, do it again until your scanner is full.
- If you have any comments please feel free to leave them here.
- Hope this helps and thanks for using FixYa.
Regards,
Tony
I think my scanner only
- The "P" means you have the scanner scanning only priority channels.
- To get rid of the "P" simply press the PRG button on the far right and bottom of the key pad and hold for 5 seconds. No the scanner should be off Priority.
- Now pick any channel that is not Locked Out and hit the "L/O" button which is the button all the way on the bottom second to the left from the wight on the keypad. Hold this for five seconds until you hear two beeps and all your channels will be unlocked and you will have free scanning capabilities again.
- Removing the "P" might be the fix right off the back depending on how many priority channels you have.
- Hope this helps and thank you for using FixYa.
Regards,
Tony
My uniden bearcat 50 channel 800mhz stop the
- You can try pressing "Manual" and then "Scan" or "Band" buttons from the weather setting to get you back to scanning the police, fire,etc.
- Make sure you don't have a WX (Weather) frequency programmed into on of the regular 50 channels or the scanner will continue to stop every time around as it will pick up the WX frequency.
- Make sure you have your scanner programmed as well.
Regards,
Tony
I have a handheld
If your locals went digital they are probably using trunked systems as well. Sorry, but there is no way to convert or modify your scanner to let you monitor the new systems. You'll need to pick up a trunking/digital scanner such as the Uniden BCD996XT. Programming the trunked systems is a real task, so I recommend that you purchase the Butel ARC XT PRO software and a subscription to RadioReference.com. The combination will let you research the systems in your area, decide which ones you want to monitor, and download them straight to your scanner.
Bill B.
Listening in since the 60's
Scanner was working fine changed battarys and now
hello remove the back panel and check the power lead going to battery compartment ,make sure batteries a installed correctly ,check the battery terminals in the compartment make sure there are no wires broken or have come loose
I recieved my fathers Uniden
Yours is a fairly simple one to program, and the best instructions are in the factory manual that you can download and print, at no cost, here:
http://www.uniden.com/pdf/BC80XLTom.pdf
BTW, they're frequencies, not codes, and you can find a great database for your area at:
www.RadioReference.com
Bill B.
How do you reload the frequencies into this
Step by step programming instructions are in the factory manual that you can download and print, free of charge, here:
For a comprehensive database of active frequencies in your area, and a lot of other useful scanning information, visit:
Bill B.
How do I do a
I don't see a master reset for your scanner, but powering it on while holding in the 2, 9, and HOLD keys works for many Uniden scanners. Otherwise, programming 0 (zero) into any channel will clear it, and programming a new frequency into any channel will delete/overwrite the previously programmed freq.
Bill B.
How to delete channels on
You can temporarily lock out a frequency by pressing the L/O key while the frequency is displayed, or can delete it by programming 0.0 (zero point zero) into the channel. Also, programming a new frequency into the channel will automatically delete/override the old frequency.
Need the manual for your scanner? You can download and print it, at no cost, here:
Bill B.
