20 Most Recent
Uniden BC898T Base Scanner Questions & Answers
Radio reference i cant get anymore
Hi Janet,I'm a little confused by your post, you state radio reference I can't get anymore. Are you referring to www.radioreference.com or something else?Yes, to use the site with explorer, you will need flash, but that's not a problem with the site, rather it's a MS issue with their dreaded web browser, Download Firefox free web browser, and it will have flash already installed ready to use on sites where flash is required, I only use firefox, and have never had issues on sites like radioreference, that require flash.I hope I got your query right and have helped you, if not, please re-post your query with full details of your issue.Cheers,Peter
My scanner was woking fine
To remove the lockout from a
channel, manually select the
channel and press L/OUT so L
disappears.try this the channels could be locked
Bc898t all 500 channels are
Locking/Unlocking Banks
When you are scanning conventional banks, the scanner displays the digit corresponding to
all unlocked banks. To lock out a bank so that the scanner does not scan its channels, press
the letter that corresponds to the bank. The bank's letter disappears from the display.
To unlock locked-out banks, simply press that bank's letter again. The bank's letter
appears on the display and the scanner includes that bank when scanning.
Note: You cannot lock out all banks. One bank must be unlocked at all times.
Locking/Unlocking Channels
To lock out a channel so that the scanner does not stop on it while scanning, press L/O
when the scanner is stopped on that channel, or manually select the channel and press L/O.
To unlock the channel, manually select it and press L/O again.
Why is it when i try to listen to the worcester
first you have to make sure you have it set for the EDACS system or the motorola system. not sure which worchester uses tho from what i have read it is edacs. after that you have to set up the talk groups... once this is done you should be able to hear them without beeps
