20 Most Recent Balance CP4401 PC Desktop Questions & Answers
It could be a number of problems.
First
Test your PSU power supply unit or replace it if your power supply units fan is not working your PSU is faulty
http://pcsupport.about.com/od/toolsofthetrade/f/powersupplytest.htm
Testing and replacing the PC power supply
http://www.youtube.com/watch?v=hbNxhvm0czs
One bad lead can cause a computer to continue on a cycle of restarting or to shutdown or fail to detect ,boot up a computer hard drive
WARNINGBefore you start troubleshooting remember that you are dealing with electricity that can KILL.
http://www.kitchentablecomputers.com/static.php - rules
Only work inside the computer case when the power has been switched off and disconnected. Never open the power source.
Some of the below steps recommend removing physical parts within the computer.
While in the computer it is highly recommend that you be aware of ESD and its potential hazards
Test all leads that attach to your hard drive power and data cables IDE ,SATA
the leads from yourMOTHERBOARD TO YOUR HARD DRIVEmake sure they have a secure dust free connections and are not faulty or just replace them they could be faulty
Make sure all leads that are attached to your dvd \ cd floppy drives have secure connections and are not faulty or just replace them they could be faulty.
Computers need power and data to travel through every working device to continue its cycle and have an end so any faulty leads will end up with a computer error.
Even something as small as a faulty electrical or fan lead can cause you problems
Motherboard and a Hard Drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail.
Check all electrical power input and extensions make sure they are securely seated even the cd/dvd floppy drives need to have current go through make sure these drives are working
also check the Cmos battery and computer RAM modules make sure they are securely seated with no dust built up or in the sockets on some motherboards cmos batteries are soldered in.
If you find you need more help with this post a reply.
Balance CP4401... | Answered on Jan 12, 2014
Click start control panel administration tools computer management device manager scroll through all of your devices If you see a yellow question or exclamation mark ? ! or a red X you will need to update the drivers for this device right click select update driver/reinstall driver if you can see your usb device but its not working scroll to Ports(Com&Ltd) right click to update driver If you computer came with a motherboard disk the drivers could be on it. Rather doing a driver hunt which can take hours http://download.cnet.com/slimdrivers-free/3000-18513_4-75279940.html Windows XP/Vista/7/8
it might take some time being a freeware driver solution Note: it will find all of your outdated drivers
This will automatically search for and find the correct driver you will have to update every driver individually once you update you might be asked whether you want to restart or make a system restore point.
Click no to both of these then continue updating each driver free then restart once all of the drivers have been updated.
Hope this helps.
Balance CP4401... | Answered on Jan 14, 2013
What is specifically wrong with the cd? Is it the drive? Let me know.
Balance CP4401... | Answered on Oct 20, 2012
A sudden shutdown or it warns you before powering off?
Balance CP4401... | Answered on Oct 04, 2012
Two conflicting statement, what is the flash? maybe what you are calling the flash was a USB Wireless Adapter that controlled your wireless internet connection.
Balance CP4401... | Answered on May 02, 2012
Hi adrake13600...
Any CD/DVD drive will fit in your computer...just make sure it is an IDE and NOT SATA connector for the computer hook up
Please take time to rate me
Balance CP4401... | Answered on Sep 10, 2011
Its probably the bearings going out in the fan. Replace it if it gets bad. newegg.com has great deals on cpu and case fans.
Balance CP4401... | Answered on Jun 11, 2011
at the post go into bios and press F9 or you can do a complete reload or recovery as new from comp or disc this will give factory settings.
hope this helps.
Balance CP4401... | Answered on Apr 27, 2010
NO NEED FOR CAPS!! You are the one who didn't back up your drivers to disc before reformat.
You need to use another PC and download the drivers from the manufacturers website.
Balance CP4401... | Answered on Mar 29, 2010
Your computer holds a max of 2GB (1GB per slot) of DDR SDRAM, DDR333. Unbuffered, Unregistered.
Refer to:
Balance cp4401 Memory
Thanks for using Fixya.
Balance CP4401... | Answered on Feb 10, 2010
You need a 220 watt - 300 watt power supply. You can place the order at the following website
http://tinyurl.com/y9q95s6
or
http://tinyurl.com/y9zlhxz
Proton
Balance CP4401... | Answered on Nov 09, 2009
Whateva
The manual you need will be on the board manufacturers web page, howevr I will bet you have the case power switch and perhaps the reset switch on the wrong pins on the mother board. To check this, remove the switch leads from the mother board, then use a small screw driver and bridge the pins on the mother board a pair at a time. All of these leads plug on to the board in a line and not across the two lines of pins. when you get the mother board to fire up by this method geet a torch and look closely alongside the pins you will see the letters PWR SW or RS SW. It does not matter what polarity these two sets of leads are plugged onto both will work. The LED lights on the case front will only work if the polarity is correct but it will not do any harm if they are backwords. On the board you should se two sets of pins marked HDD and PWR these are the led light pins you will know you have them right when the usual red and green lights are working at the front of your tower. Regards mistyman
Balance CP4401... | Answered on Nov 08, 2009
pls.... check the memory of that pc.because the memory not funtioning properly. remove the cover of the pc and then pls. hold the both side of the the slot of memory and press it down.then remove the memory cnd clean it to tisue. if finish put it to the same position then try to on again...if not functioning the pc pls......of your pc and removed the cmos battery then try on with 5 seconds without the battery then of the pc and then on again..........
Balance CP4401... | Answered on Sep 21, 2009
perhaps the resolution is set to a value that the monitor cant display (try other monitors) or if using windows tap F8 at start up and start in SAFE MODE this will start the display driver in minimal resolution and if alls ok you should see a picture
Balance CP4401... | Answered on Jul 14, 2009
Sounds like you need a new charger. If the charger doesnt fix it then try a new battery. Before you buy either one, check the charge port in the back of the laptop, sometimes they crack off and just need a bit of solder to make a good connection to the motherboard.
Balance CP4401... | Answered on Jun 04, 2009
eric, YOur LCD support upto 1440X900. this could be true if you use higher resolution VGA adapter in you PC.
This matter in the Video Adapter.
may this help,
melnavz
PS:
pls donot rate me if this solution donot satisfy you. However; if this help, pls rate me reasonable rating. thank you.
thanks for using fixya.
Balance CP4401... | Answered on May 16, 2009
Hi, that machine will take DDR266, DDR333, or DDR400 RAM according to the Tech Specs. All the RAM in this class uses the same form factor, so they're interchangable on motherboards, but the higher speeds run faster. You can find the specs here:
http://www.walmart.com/catalog/product.gsp?product_id=3321522
Balance CP4401... | Answered on May 13, 2009
Balance CP4401 PC Desktop Logo
36 questions posted
Top Balance Computers & Internet Experts
Jaime Hernandez
Steve Allison
Steve Allison
Jerry Greenberg
Jerry Greenberg
Are you a Balance Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Balance Computers & Internet
Most Popular Question
balance cp4401 pc desktop restore
  • Computers & Internet
