20 Most Recent
Fuzzbuster F4000 Radar Detector Questions & Answers
How do u operate a
plug the unit's power cord into your lighter socket and your good to go! For more information on this model go to
www.whistlergroup.com for info and FAQ's on operation of this model.
Manuel fuzz buster FB 3500
First this is not a Whistler Product. Second what is the problem with the unit? Is it a F3500 or F4000?
I aquired a Whistler 1430
The 1430 is an old detector and the manual is not available online. Have you checked Whistler's FAQ page at their website?
www.whistlergroup.com Its a basic unit and just plugging it in and turning it on is all you need to do.
Where can i buy a windshield suction mount for a
First this is not a Whistler made radar detector - it was made by Fuzzbuster. With that said, you might be able to use a Whistler bracket. If you know of someone that has a Whistler radar detector, try to see if your unit will work with it. If so, then you can call 800-531-0004 to order a windshield bracket or order it on Whistler's website - www.whsitlergroup.com
Fuzzbuster fb-3500 speaker not working
First this is not a Whistler made radar detector - it was made by Fuzzbuster. You can try some electronic parts suppliers to source a speaker for your unit.
:ow do I program the fuzz buster f4000
First this is not a Whistler made radar detector - it was made by Fuzzbuster. There is nothing to program - turn it on and it will pick up all the bands
Broken Display
Sorry but Fuzzbuster is not a Whistler Product but manufactured by Fuzzbuster which i beleive is no longer in business.
Specs for whistler 975 power cord what's the output
Product detailsCar charger For Whistler 925 945 975 1125 1200 Series Radar Detector Power Cable Power Payless All products are new and fully-tested OEM equivalent replacement parts Input voltage: 100V ~ 240Vac 50/60 Hz Overload protection Short circuit protection Over Temperature protection Power Saver Protection 100% HI-POT tested 100% cycling burn-inContact us for any question before leaving none-5 star feedback.Specialty Service in Power Supply,Satisfaction guaranteed ! How much power does a dash cam usePlease note that this is a quality compatible adapter, picture is justfor reference. It may looks different from the physical adapter youreceived. Sometimes, we even will send you a brand name adapter that is compatible with the one advertised.Source Link:https://www.newegg.com/toplab-hrnbl-b07kdjxn9l/p/0FB-06J3-00046?Description=cr93,whistler&cm_re=cr93,whistler-_-0FB-06J3-00046-_-Product
How to perform a factory reset on whistler WS1025 scanner
Configuring Your Scanner
Preprogrammed Frequencies
Your scanner includes 153 preprogrammed
frequencies, which you can load into Channels
1 to 153. For a list of these frequencies, see
"Preprogrammed Frequency List" on page 23.
To load the pregprogrammed frequencies:
1. Turn off the scanner and then turn it on again.
2. While WELCOME message appears, press PGM.
3. Load -Fr- appears, then YES--Ent and No --
CLEAr appear alternately.
4. Press ENT to load frequencies or CLEAR to
cancel.
Programming Channels
If you do not have a list of frequencies in your area,
refer to www.radioreference.com.
1. Press PGM. PGM appears.
2. Enter the channel number (1-200) where you
want to store a frequency, then press PGM again.
3. Use the number keys and • to enter the frequency
(including the decimal point), then press ENT.
4. To program the next channel in sequence, press
PGM and repeat Step 3. To program a specific
channel repeat Steps 2 and 3..
• Your scanner automatically rounds down to
the closest valid frequency. For example, if
you enter 151.473, your scanner rounds it to
151.470.
• If Error appears and the scanner beeps three
times when you press ENT, start again from
Step 2.
• If the frequency is already stored in another
channel, the scanner beeps three times and
displays -dUPL- (duplicate) and the lowest
channel number where the frequency is already
stored. Press TUNE/CLEAR to cancel. Press
ENT if you still want to store the frequency.
What's vg2 mean on 1530 Whistler
The VG-2 button is to engage VG-2 Cloaking Technology. From what I can see VG-2 Cloaking Technology is a way the detector has of avoiding being detected by authorities in areas where the use of radar detectors is prohibited. I am not in a position to say how effective this is, I suggest you refer to reviews. I have only researched the meaning of VG-2.Rider here: Please do your own research on the effectiveness of this technology on this - or any - detector.Of course the best way to avoid being picked up for speeding is not to speed. (But you knew that..)
