20 Most Recent
Fuji FinePix Z1 Digital Camera Questions & Answers
I have a FinePix Z1
try a different battery - how old is the camera - the voltage may be too low, hence it turns off.
Lens cover stuck
memory card slot/battery cover was open with the POWER ON.fix it.God bless you
Fuji Finepix Z1 Zoom Error
I saw another post in this forum were someone suggest banging it on a table a couple times, not to hard that you'd dent it but a good enough bang. Worked like a charm! I tried the trigger and slide method but while the error message went away the zoom wouldn't focus. Try banging it, it sounds bad but it worked wonders!
Lines are shown when the
If there are no distortions on the picture seen on the camera viewfinder then there is some issue with the picture manager software.If the images seen on the PC are also showing clean pictures, then there fault on the transfer or the camera driver software. Remove the SD card and insert into the PC using the card reader- use in any laptop- if the picture is clean , then uninstall the camera driver and reinstall, then connect to transfer. If the fault is seen the download another version from the camera support site to be installed.
Camera says Card Not Initialised
Download any pics from the card using a card reader if necessary. Then, go into the menu and find "format" or "Initialize" and follow the on-screen instructions.
How to take my photo on delayed timer?
Press cursor-down (marked with a one-handed clock) to cycle through the different self-timer modes. Your choices are off, two-second delay, and ten-second delay. Start the self-timer by pressing the shutter release button.
My z1 when connected to pc will not download
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
When i turn on my
Hello
Thank you for using Fixya!!!
Before you try anything, try using another card. If the problem persists, try the suggestions below.
OK, if the memory card itself is locked, you might
sometimes get this error code. All you need to do is to take out the
memory card and switch the lever on the left side to the unlock.
If
the error is still displayed after you did the above, you might want to
try the card in another camera.
If
the card works in another camera . the problem is with your card reader
in your camera.
If you open you sd slot and look inside with a
sharp light , you should be able to see on the left side of the slot
there is a little copper or spring steel lever switch. This switch work
as follows:
1. When no card is inserted / no write protection ,
the switch is open and thus the protection is off.
2. When locked
card is inserted , the tab is depressed and tells the camera that the
card is lock.
Contrary to popular belief ,the little tab on the
sd card is not an electronic switch and does not physically influence
the card operation itself. If you put a locked card into a camera
without a sd lock switch , you would still be able to use the card
normally.
It is incredible difficult to fix this switch because
of space limitations in the sd card. Look into the sd slot and if you
can see the switch , use a needle to pull the little tab down toward the
base of the camera by about 2mm or until it works being careful not to
bend it.
If this does not resolve your problem , there might be a
short in the switch circuit and the camera will need to be disassembled
to resolve this error. This should cost no more than $50.
Please
feel free to contact me if you need further information
Kind
regards
Andrea
Battery doesn't fully charge. Over three years. Do
I have the same problem, maybe. My Z1 worked fine for maybe 4 years, it was a rebuilt one with original battery. After much use, videos etc, I replaced the battery and even bought a charger. This has not really helped. When I slide it open I get zoom error. When I press the button to review and set format it goes off while I am in the process of setting the date. What to do? Jan 12, 2011
Zoom error and intermittent flash out of sync
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the
probability is that you will have to get it fixed by a professional.
Use
these at own risk as it may further damage the camera.
Firstly ,
try connecting your ac adapter or usb cable.
Try holding the
shutter button while switching on the camera.
Look at the lens ,
and if some of the lens 'circles' is misaligned or not concentric then
try wiggling it (while holding camera lens down).
Try gently
pushing or pulling the lens when it extends but this is risky as it may
cause the lens barrel to slip out of its guidance system.
Another
way to do this is to place the camera lens down on a hard surface and
then power it up. Be sure to use a soft cloth or something similar as to
not scratch your lens or casing. Let the lens push the camera up and
down a few times and sometimes the little resistance provided by the
camera is enough to get things going again.
Try hitting your
camera near the lens on the body with the soft tissue on the palm of
your hand.
Other than that , I would take the camera to a repair
center for a evaluation to see if it would cost more to repair than to
replace the camera.
If it is still under warranty I would suggest
you take it in before trying any of these steps and remove any
off-brand batteries or accessories as some stores are really fussy about
warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope
the advise is useful. please do not hesitate to let me know if you need
any further assistance. Also, please be so kind to let me know if you
found this helpful.
Regards
Andrea
The screen just says zoom error
Hello
Use
Firstly ,
Try holding the
Look at the lens ,
Try gently
Another
Try hitting your
your hand.
replace the camera.
Hope
the advise is useful. please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
Error zoom fujifilm s700
Hello
Use
Firstly ,
Try holding the
Look at the lens ,
Try gently
Another
Try hitting your
your hand.
replace the camera.
Hope
Regards
Andrea
MY CAMERA (FINEPIX Z1) STOPPED
Please let us know whether the camera is still under warranty. Also, kindly specify your country/region so that we can provide you with the relevant information.
Kindly reply to this post with the details. Thanks for using FixYa.
