20 Most Recent Fuji FinePix E550 Digital Camera Questions & Answers
0answers
0answers
When plugged into my computer, the pictures on the camera no longer transfer to the computer
Consider NOT connecting your camera to your computer.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
9/4/2012 2:58:59 PM • Fuji FinePix... • Answered on Sep 04, 2012
When I turn on my camers you can see a blank screen but cant see anything nor take pictures
Hi there:Some symptoms of a defective CCD include distorted images or abnormal colors, scratchy purple lines, blank or black pictures, and/or black videos with good sound being recorded on the camera's flash card.A CCD problem would explain the lines on your pictures and the lines on the LCD (since the CCD is used to feed the live image). CCD (Charge Coupled Device) is one of the two main types of image sensors used in digital cameras.When a picture is taken, the CCD is struck by light coming through the camera's lens. Each of the thousands or millions of tiny pixels that make up the CCD convert this light into electrons. The number of electrons, usually described as the pixel's accumulated charge, is measured, then converted to a digital value. This last step occurs outside the CCD, in a camera component called an analog-to-digital converter.In order to correct this issue, the repair facility needs to replace the CCD. This is not something you may do on your own; check this article for additional details:Bad CCDs. This, isn't a good new, but hope helps to solve it.Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.Thank you for using FixYa, have a nice day.
8/22/2012 3:57:18 PM • Fuji FinePix... • Answered on Aug 22, 2012
2answers
Camera only half operates: preview mode OK, picture-taking mode not working
Mine shuts off when I press the shutter button. I put in new batteries and I can get the lens in then. But it shuts off when I try to take a picture. These cameras are notorious for having a zoom problem. They say the Zoom error appears and the camera dies. There is a fix of gently pulling the lens out all the way till the cover open then twisting it gently clock wise till it clicks. They say this fixes this problem but I don't think that is what is wrong with mine. Do a search on Fuji E550 zoom problem fix. It should show up.
8/14/2012 7:37:22 PM • Fuji FinePix... • Answered on Aug 14, 2012
Why is my fuji digital camera film not downloading, and not giving me any download soft ware
The actual card may have a sliding lock on the side or.. You may have a button on camera to help secure pictures from being deleted or downloaded.
6/25/2012 3:14:19 PM • Fuji FinePix... • Answered on Jun 25, 2012
Require usb interface to my computer
Do you really need the USB interface?The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa.
3/5/2012 5:22:43 AM • Fuji FinePix... • Answered on Mar 05, 2012
Zoom Error message, lens does
The lens error indicates that the movement is inhibited possibly by sand or grit. It also may be misaligned or an internal component has failed. Here are a few links to some other things to try. With newer cameras I am usually hesitant to suggest these options since they include some more extreme procedures that may cause further damage if not done correctly, but since yours is probably no longer under warranty, they may save you an expensive repair bill. An older Canon camera is used to demonstrate these procedures but, the lens structure of these compact cameras is the same so the examples do apply to this unit. These procedures are effective about 60% of the time. Click on or copy and paste the links into your browser.
Lens Covers
* Lens FIX 1
* Lens FIX 2
If the "do it yourself" approach doesn't work out for you and you need conventional repair you can get an online estimate at the link and please see the note below: unitedcamera.com/FUJI-FINEPIX-E550
Hope helps.
9/14/2011 1:55:23 AM • Fuji FinePix... • Answered on Sep 14, 2011
My fuji E550 lets me
This is most likely an issue with the camera's image sensor. Your camera will need to be repaired by an authorized Fujifilm service center. Contact Fuji though as sometimes they have service advisories for issues such as this.
Hiram
Photo Tech Repair Service
110 East 13th Street
New York, NY 10003
212-673-8400
7/5/2011 3:07:55 PM • Fuji FinePix... • Answered on Jul 05, 2011
Hi ,i mis the usb cord for my camera a finepix e
Consider NOT using a USB driver.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
4/29/2011 4:15:19 AM • Fuji FinePix... • Answered on Apr 29, 2011
The camera cann't get GPS
No camera can get a GPS signal in China....the companies do not offer a reason.
4/21/2011 8:57:08 PM • Fuji FinePix... • Answered on Apr 21, 2011
Lens decided not to function. a mechanical
Mechanical problem can be made fine by the service centre only.They are really complicated inside.I suggest you to take the camera to the authorized service centre and do it.
Thank You
2/22/2011 2:37:32 AM • Fuji FinePix... • Answered on Feb 22, 2011
Finepix e550 about 6 years
YES HAD THE SAME PROBLEM..DIRTY BATTERY TERMINALS..SCRAPE WITH A FLAT BLADE SCREWDRIVER..LIGHTLY JUST ONCE..? POLISH BATTERY TERMINALS..A LIGHT RUB..SHOULD KICK INTO LIFE..DO THIS EVERY TIME NEW BATTERIES FITTED..HOPE THIS HELPS..P.S. THESE CAMERAS LOVE GOOD QUALITY FULLY CHARGED BATTERIES..NOT CHEAP ONES.???
2/20/2011 8:28:56 PM • Fuji FinePix... • Answered on Feb 20, 2011
CLEANED DIRTY BATTERY TERMINALS..NOW SWITCHES ON
You have an electric circuit problem that requires service. This could be expensive.
2/20/2011 8:23:12 PM • Fuji FinePix... • Answered on Feb 20, 2011
Fuji FinePix E550 Digital Camera Logo
128 questions posted
Top Fuji Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Fuji Camera Expert? Answer questions, earn points and help others
View Most Popular
FinePix Fuji
  • FinePix Fuji
Most Popular Question
when plugged into computer pictures
  • Cameras
