20 Most Recent
Emerson EWD7001 DVD Player Questions & Answers
Trying to hook up an emerson dvd player to tv and
IM GUESSING THIS MIGHT BE AN RCA TELEVISION? if you dont have an rca in hook up on the tv give up and buy a new tv or you can find an older item what it is is a switch that has an rca input and a coax output it was used to hook up the older video game systems it is still sold in most stores and that will work if you do have rca inputs and lost the remote you need to get a universal remote to switch the input on certain older rca tv's you could go to channel 00 and it would set it to the input with the switch you shoudl be able to use it by putting the tv on channel 3
Presidian DVD Recorder
i have a presidian dvd recorder and when i put in
a new blank dvd-r disc it only gets it prepared up to
21% and tthen it stops and opens
How to connect my Presidian DVD Player to my TV correctly
Well
you should be able to play it on your tv it doesn't have to be connected to a cable box.
if it doesn't I would need to know the brand and model of the tv and the combo player. and what cables are you using and where are they connected?
Thanks
Emerson TV and DVD
Go to service manuel .net U might find a manuel for this unit ( might )
How to setup a onn remote control to a emerson TV
1. Turn on your Emerson TV.
2. Consult the ONN remote manual for Emerson TV codes.
3. Press TV on the ONN remote.
4. Enter the correct code.
5. Test remote functions.
- If unsuccessful, try code search or auto-programming.
6. Ensure compatibility.
1/8/2024 3:58:07 PM •
Emerson...
Answered
on Jan 08, 2024
My Emerson DVD player says Disc Error Playback feature may not be available on this disc
The error message "Disc Error Playback feature may not be available on this disc" can have a few different causes. Here are some of the most common:
- The disc is not compatible with the DVD player. Some DVD players are only compatible with certain regions or formats of discs. If the disc you are trying to play is not compatible with your DVD player, you will get this error message.
- The disc is damaged. If the disc is scratched, dirty, or otherwise damaged, it may not be able to be read by the DVD player.
- The DVD player is faulty. If the DVD player is faulty, it may not be able to read discs correctly.
Here are some things you can try to fix the problem:
- Try playing the disc in another DVD player. If the disc plays in another DVD player, then the problem is with your DVD player.
- Clean the disc. Use a soft, dry cloth to clean the disc. Be careful not to scratch the disc.
- Format the disc. If the disc is formatted for a different region or format, you may need to format it for your DVD player.
- Reset the DVD player. If the DVD player is faulty, you may need to reset it.
If you have tried all of these things and you are still getting the error message, then you may need to replace the DVD player.
7/6/2023 7:52:52 PM •
Emerson...
Answered
on Jul 06, 2023
Anyone know the start and run cap values on an Emerson LR63596 model T63XWBSS1486, labels have deteriorated
The capacitor values for the Emerson LR63596 model T63XWBSS1486 motor will depend on the specific application and the motor's specifications. Without more information about the motor's voltage, horsepower, and other details, it's difficult to give a precise answer.
However, as a general rule, the capacitor values for single-phase AC motors like the Emerson LR63596 typically range from around 5-80 microfarads (µF) for the start capacitor, and 5-100 µF for the run capacitor.
That being said, it's important to note that the specific capacitor values required for your motor may be different, and using the wrong values could cause damage to the motor or affect its performance. Therefore, it's recommended to consult the motor's documentation or a qualified technician to determine the correct capacitor values for your specific application.
6/27/2023 5:47:05 PM •
Emerson...
Answered
on Jun 27, 2023
Where are fuses on a Emerson TV model # LD190EM2
Fuses are solder in, and chances of a fuse blowing without other bad components are slim, take it in for service or better yet buy a new TV unless you have a multimeter and know how to trouble shoot a tv
6/25/2023 4:56:05 PM •
Emerson...
Answered
on Jun 25, 2023
Emerson LTDN42V68US television will not power on. The light just blinks red continuously ..
What's happening with your TV is the backlight inverter is sensing over current and shutting the entire power supply down (excluding the standby supply) this gives the 1 blink code. Reason for over current is open circuit in the LED backlights, you will need to replace the lamps to fix the issue, there is about a 2% chance of it being a faulty power supply but in most cases it's the lamps. This is common on most Funai brand sets.
4/8/2023 3:47:08 PM •
Emerson...
Answered
on Apr 08, 2023
How come my Daewoo remote 97p1803700 will not work anymore?
The issue with your Daewoo remote 97p1803700 may be due to battery depletion, broken buttons, or internal damage. To resolve the issue, you could try changing the batteries, checking the buttons for any physical damage, and cleaning the interior of the remote control. If these steps do not resolve the issue, you may need to take the remote control to a professional repair service. As for the eject button, the functionality may be limited by the remote control model and the device it is controlling. It may not be possible to add an eject button to your current remote control, but you could look for alternative remote control models that offer the eject button
2/3/2023 5:31:22 PM •
Emerson...
Answered
on Feb 03, 2023
