20 Most Recent Emerson EWC19T3 19 in. TV/VCR/DVD Combo Questions & Answers
2answers
Emerson tv dvd combo lost
hey Sweet
sorry no! but you can order an orignal replacement remote from here www.remotes.com and that wikk fix your problem!
Please rate answer!
Thank You!
11/11/2023 11:14:38 PM • Emerson EWC19T3... • Answered on Nov 11, 2023
Have a Emerson tv - EWC 19T2 TV/VCR/DVD, it was
There is no reset for the remote that I know of.
6/27/2017 3:51:26 PM • Emerson EWC19T3... • Answered on Jun 27, 2017
2answers
Need code for universal remote
Try these codes: Emerson 011, 026, 027, 028, 029, 030, 031, 032, 037, 042, 053, 064, 065, 067, 075, 076, 079
This is from: <http://www.bobvila.com/Global/FAQ/Detail-93.html>
Hope this helps.
12/22/2015 4:38:20 PM • Emerson EWC19T3... • Answered on Dec 22, 2015
Whay is the codes for a insignia tv
0101 0152 0195. Try these codes. If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" or "Magazine" view. It will make surf easier. http://electrohelponline.blogspot.com/ Try this link too http://remotesearch.blogspot.com/
4/28/2014 4:57:52 PM • Emerson EWC19T3... • Answered on Apr 28, 2014
0answers
I lost remote and i want to run auto scan,how do i do that with out remote for tv?
You really need that original remote--universal will not do it and it cannot be done manually.Good luck as Emerson can be difficult as far as getting anything.
4/23/2012 2:25:58 PM • Emerson EWC19T3... • Answered on Apr 23, 2012
Hi, I have sent an email to FixYa in reference to
Hi carri160, First of all, thank you for posting your question here at Fixya.Emerson EWC19T3 original remote control is no longer available. The only available now is the substitute remote control that provide similar functionality to the original one. Please click here to open the link in a new tab.Hope I helped you!Have a great day!Good luck and take care!mjsazon
1/28/2012 1:22:38 AM • Emerson EWC19T3... • Answered on Jan 28, 2012
I need code for tv
Hello
Three digit universal remote code for emerson are:-
004/ 009/ 014/ 023/ 024/ 025/ 026/ 027/ 030/ 032/ 033/ 034/ 035/ 036/ 037/ 038/ 039/ 040/ 041/ 042/ 043/ 045/ 046/ 049/ 053/ 116/ 135/ 147/ 177/ 179
Four digit universal remote code for Emerson TV/vcr combo are:-
0456 [0458 0227] Where the code is listed as [### ###] the first is for the DVD and the second is for the VCR. Otherwise just the one code operates both the DVD and the VCR Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Code Search If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Also try these four digit codes for Emerson Tv also. There are so many codes for Emerson Tv. 0004 0009 0044 0135 0049 0051 0189 0053 0147 0039 0130 0227 0233 0250 0252 0254 0257 0265 0266 0310 0325 0456 0040 0041 0042 0021 0023 0024 0179 0045 0025 0027 0030 0032 0034 0035 0037
1/3/2012 5:05:10 AM • Emerson EWC19T3... • Answered on Jan 03, 2012
6answers
My Tv is turning off by itself
if all you want to do is disable the vcr portion turn the set on , install a blank vhs tape it has to be blank or the vcr will try to read it .and the tv and dvd should work fine. this is a timing problem in the vcr deck its not hard to fix but it is a pain.
9/26/2011 3:14:11 AM • Emerson EWC19T3... • Answered on Sep 26, 2011
0answers
Emerson EWC19T3 19 in. TV/VCR/DVD Combo Logo
Popular Tags
154 questions posted
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Emerson Televison & Video
Most Popular Question
need code tv
  • Televison & Video
