20 Most Recent Emerson EWC1903 19 in. TV/VCR Combo Questions & Answers
2answers
Every time i put a
Sounds like your vhs take up wheel is not doing its job. Vhs unit needs repair or replacement.
12/15/2023 5:15:34 AM • Emerson EWC1903... • Answered on Dec 15, 2023
0answers
Turns on but turns off automatically after being on 5-10 seconds, HELP!!!
The belt of the charge motor of the vcr are in bad conditions you gotta cnange it.Thats all the problem.
7/12/2013 3:34:39 PM • Emerson EWC1903... • Answered on Jul 12, 2013
Every time i put a vhs in, it says rental play, how do i turn it off rental?
It will be in the set menu and you need the original remote to try to correct it.
4/23/2012 2:29:52 PM • Emerson EWC1903... • Answered on Apr 23, 2012
Can you tell me the
try this:
004
009
014
023 024 025 026 027
030 032 033 034 035
036 037 038 039 040
or this:
11864
3/23/2011 3:21:48 PM • Emerson EWC1903... • Answered on Mar 23, 2011
Can't change channels with buttons on tv-lost
If you can access the Menu you need to do a channel scan and that should restore your channel function also for a replacement go to http://www.replacementremotes.com/
12/2/2010 9:55:39 PM • Emerson EWC1903... • Answered on Dec 02, 2010
TV remote was lost and I want to use universal
try this link to download a manual, it will be in there somewhere.
1/5/2010 5:57:32 AM • Emerson EWC1903... • Answered on Jan 05, 2010
I have several older dvds recorders which use 4x
Do you have any "£1" shops in your area, "Pound World", "Pound Empire",etc. We have 3 here. All have old 4x DVDrecordable disks.
9/13/2009 11:50:02 AM • Emerson EWC1903... • Answered on Sep 13, 2009
3answers
Need code for universal remote control for EWC 1903 19 in. tv/vcr
What is the make of the Universal Remote Control?
2/2/2009 1:32:42 AM • Emerson EWC1903... • Answered on Feb 02, 2009
No sound,volume bar works
Sorry I dont have a manual but it is available at http://www.servicemanuals.net If you put your ear close to the speaker, with the volume turned up, do you hear any hiss or buzzing? If you dont it could be a bad speaker,headphone jack(if there is one), or the audio output IC or ascoiatated componets. If there is a hiss, then theres a problem with the audio processor or switching IC. If your not a tech, you should not be experimenenting around inside this TV set!
7/8/2008 11:37:45 PM • Emerson EWC1903... • Answered on Jul 08, 2008
Tv off by itself.
Oye tu problema es que el sistema de la vcr esta fuera de tiempo,trata cambiandole la banda de el motor de carga ya que si esta se encuentra desgastada patina y haceque el micro detecte error y por eso se apaga el televisor.Suerte.
4/18/2008 8:12:00 PM • Emerson EWC1903... • Answered on Apr 18, 2008
I have the 13 inch and...
If you get channels 2 to 13 nice and clear but the rest are snowy, it means that the TV is set to the broadcast channels, which means that for the channels above 13 it is tuning in the old-fashioned UHF channels. If the TV is set to the cable mode then it tunes in cable channels above 13. To do this, enter the menu and navigate to the tuner settings, set the tuner to standard cable and then do the autoprogram, and the tuner's memory will be set for your cable system.
8/5/2007 7:31:33 AM • Emerson EWC1903... • Answered on Aug 05, 2007
Tv wont turn on
The sound can be called screaming from the power supply,it senses a short and creates a frequency you can hear,the set has a problem and it needs to be repaired,I will check the horizontal out put transistor for a short,sometimes it goes bad without a reason and sometimes the high voltage transformer is also bad and both have to be replaced but first the transistor only if it goes bad again then you replaced the transformer too.Seek assistance from a servicer if you are not too familiar with tv service,it can be dangerous.
10/2/2006 4:28:58 PM • Emerson EWC1903... • Answered on Oct 02, 2006
Sounds like it may be something you did. Have you checked to see if you accidentally put the sound on mute? Try hitting the mute button on the remote control. Also, if the TV has the option to turn of internal speakers (which you would likely find in the menu under audio settings if it does) make sure they are turned on. If these checks fail then we have an electronic problem to deal with.
9/1/2006 4:19:31 AM • Emerson EWC1903... • Answered on Sep 01, 2006
How to setup a onn remote control to a emerson TV
1. Turn on your Emerson TV. 2. Consult the ONN remote manual for Emerson TV codes. 3. Press TV on the ONN remote. 4. Enter the correct code. 5. Test remote functions. - If unsuccessful, try code search or auto-programming. 6. Ensure compatibility.
1/8/2024 3:58:07 PM • Emerson... • Answered on Jan 08, 2024
I have a ONN remote model CR-55A1 . I want to setup it up to control my Emerson Television.
I can't find anything that says what the DR-55A1 is? Is it a Onn Universal Remote or to a specific item like a DVD or ONN Television? If it is, you can't do that, one device, one code. https://www.fixya.com/support/r29872378-universal_remotes_no_facsimile_remote
onnremotes
ONN Remote Control https://www.onnremotes.com Your ONN remote can control up to 6 devices and is remarkably easy to set up. These video tutorials will give you step-by-step instructions for programming the ... Missing: 55A1 ‎' Show results with: 55A1 ..
1/8/2024 2:15:46 AM • Emerson... • Answered on Jan 08, 2024
QR code for 55" Emerson tv model LF501EM4A
No idea what you mean and neither does Google. Why do you want a QR Code? https://www.google.com/search?q=Emerson+LF501EM4A+QR+code https://www.google.com/search?q=Emerson+LF501EM4A ..
1/2/2024 9:29:02 PM • Emerson... • Answered on Jan 02, 2024
Emerson EWC1903 19 in. TV/VCR Combo Logo
Popular Tags
21 questions posted
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Emerson Televison & Video
Most Popular Question
turns but turns off automatically after
  • Televison & Video
