Regular maintenance of your Compaq Presario laptop helps to keep the machine running properly.
Keeping the fans clean is especially important, because the fans blow out hot air and bring in fresh air to cool down the laptop.
Fans attract dust, however, which can slow them down, resulting in a hot laptop.
If the laptop overheats, vital parts can cease functioning altogether.
Consequently, keeping your laptop's fans clean is crucial.
or Remove an HP Presario C500 Fan Assembly to clean it
HP Presario C500 is a laptop that, like most other laptops, requires a clean, functioning fan in order to work properly.
If your fan is too full of dust to function properly or needs to be replaced because it is no longer working, then your computer could be in danger of overheating and crashing.
Instead of having to purchase a new laptop because your C500's fan has failed, remove it and clean the fan or replace it with a new one.
Turn off your computer and unplug all the cords and cables from it, even the power cable.
Turn the laptop over and remove the battery, then remove all the screws at the bottom of the computer with a Phillips-head screwdriver.
Remove the two face plates from the bottom of the computer and you'll see the hard drive and RAM below.
The face plates will come out easily once the screws are removed.
Remove the two screws holding the hard drive in place and then lift the hard drive out.
Remove the screw found directly below the hard drive.
Turn the laptop over again and pop off the keyboard.
If all the screws at the bottom of the computer where removed, then the keyboard will come right out.
Remove all the screws underneath the keyboard and case and then lift the case enough to access the fan assembly in your HP Presario C500.
Unhook the cable coming from the fan into the motherboard and remove the screws holding the fan in place, then pop the fan out of the computer.
Hope this helps
or you might want to remove it to get it clean
Hope this helps
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrative tools computer management device manager scroll to sound video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
click start control panel sounds and audio volume advanced speakers make sure you have selected the
(appropriate speakers) also audio you will find 3 drop down lists make sure you have selected the correct speaker settings there
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
if his does not fix the problem
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the speaker volume icon system select adjust volume
click start control panel sounds and audio volume advanced speakers select the appropriate speakers
from the drop down list or navigate to the device manager scroll to system devices + to expand system speaker right click properties then select use this device (enable) also you might check
the speaker plug/outlets is usually at the side of the laptop you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good with no dust as dust causes static electricity
clean your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
http://download.cnet.com/2000-20_4.html
on the home page you should see a search tab just type in what you are looking for
IE: motherboard name audio driver you might have to try a few times to get it right
for windows 7
click start right click on computer select properties then device manager scroll to sound and video game controllers if you see a yellow question/exclamation mark or a red X the driver will need to update drivers
click start right click on computer select properties then device manager scroll to sound and video if you right click on sound and video then on high definition audio device select update driver software
click start control panel hardware and sound manage audio devices right click on your speaker select configure speakers
right click on the speaker icon in the bottom taskbar you will see an array of options select
playback devices make sure it has a green tick and the correct speakers are selected
be updated if you computer came with a motherboard disk the drivers could be on it although
once speakers are connected widows 7 should automatically update the drivers
click start control panel hardware and sound manage audio devices playback you might have to set a default go for via high definition audio then right click on speaker
you might have to configure them then select properties you will see tabs general level in this tab make sure your settings are loud enough also enhancements and advanced from the drop down
list in the advanced tab select dvd quality or another then apply
hope this helps
17 questions posted
3,409 Questions
2,234 Questions
1,799 Questions
796 Questions
724 Questions
