20 Most Recent
Packard Bell EASYNOTE F5280 COMPATIBLE LAPTOP LCD SCREEN 154 WXGA GLOSSY CCFL (22099229322) Questions & Answers
I forgot my user password
Login with your administrator using your password which you had set at the time of installing operating system, if you had set no password then leave the password field blank and after login go to the control panel--->user accounts and delete your previous user and create user again with your desired password but backup the user data before deleting it.If you want more assistance about this, you can contact me directly.Hope you will satisfy.
Packard Bell iMedia S3720 startup problem
The battery charges the BIOS and is not utilized directly. Sometimes it takes a few days for it to take effect. Placing the battery may have stressed the Setup so my advise is to reset the BIOS. There may be a jumper over two out of three pins and reset takes as much as placing it over the other two for a couple of seconds. When this does not work then remove the battery and replace it after waiting but are you sure the battery is placed right, deep enough and not upside down? Some computers have two contacts that should be shorted out for a moment.
I am not sure what you mean by removed harddisk. It may not function without a suitable harddisk and one fit for the limitations of the BIOS version. When it is on PATA cables, then make sure the Master/Slave jumper is set and the cable its longer end is on the motherboard controller.
Beeps usually give an error code, where a long beep may indicate that a harddisk wasn't found. The very short and almost silent beep means the memory can be tested prior to boot. Perhaps the memory is unfit or displaced.
When any of this does not help you may need some-one on site to take a look at it. PSU's can be diagnosed with a tester plug and those don't have to cost much.
What might be the problem if my laptop doesn't get to password stage? It stuck on the Packard bell logo
What might be the problem if my laptop doesn't get to password stage? It stuck on the Packard bell logo?
well the PC is not 100% dead, and the screen works
no model PB told at all or sold in what country?> where?
this can be simple to worse. (20 things can fail here)
1:: do the 10second long power button reset.? cures stuck sleep
fails.
2: remove the huge battery and RUN on AC power pack only?
batteries are A#1 case of failures and this test is fast and proof.
fails
3: the coin cell battery is dead. replace it. (and reset bios)
fails.
4: the HDD is dead. 5 years old?
no PC told at all and no way for me to judge age, I do tests based on AGE> of PC> to save time , labor and cost of buying useless parts.
5: take unstated PC to a shop, in your unstated town and bingo.
it was not sold in USA./ for decade
and is owned and made by acer.com now.
see the flags here, see yours, , not told you
https://www.packardbell.com/index.html
notebooks
netbook?
tablet
or chromebook???????????????????
