20 Most Recent
Philips DVDR70 DVD Recorder Questions & Answers
I have a philips dvdr70
From the Sky box, plug one SCART lead to your recorder and plug another to your TV. Then plug a SCART from the TV to the recorder.You can then select the SCART connector for the sky box to record programs.This will work after the digital switchover. The switchover is only for 'normal' tv signals from your tv aerial
I have a Phillips DVDR70 player.
You need to unlock the player before it will play discs from other regions. UK has region 2 discs while the US has region 1.Search on Google for your DVD model and unlock code.Dial in the code using your remote and you should then be able to play any region discs from around the world.
How to connect to sky
Plug your recorder into the SCART connection labelled VCR and plug that into a SCART connector on your recorder.To record from the Sky box, change the input channel to the SCART connector that the Sky box is plugged into and record away!
Cannot get dvd to move
Is the camera switched on when you are switching to CAM1?Some units won;t switch to an input if there isn't anything going through it...
After recording onto a dvd+rw
Are the new discs compatible with the recorder? Some discs are DVD R+ or DVD R- so check that bit and see if that matches what it says the recorder will run.
My Philips DVDR70 DVD Recorder
Has it been knocked about a bit? If this has been dropped or hit by something, the laser might be off alignment. Usually the only way to fix this is replace the laser. If not, can you check if it has dirt on the laser lens? If you have a DVD lens cleaning disc this could remove any dirt off the lens.
I cant get dvd recorder to record ext 2
Firstly, is the scart lead plugged in fully? Does it get the sound or nothing? Is the recorder sitched to the correct input? It may be trying to pull a signal from the TV which may not be passing through the picture from the sky box. Also, is the scart lead fully wired? Some only work one way so try spinning it round between the recorder and sky box.
CANNOT TUNE TV CHANNELS FROM
You need to purchase a digital converter box in order to receive the proper signal, the only exception would be if your antenna is digital ready. I would suggest talking to a tv tech to find out if you need additional changes.
