20 Most Recent
Philips E-Box FTR9965 DTV Receiver Questions & Answers
TV SET ON STAND BY?
This is to do with the capacitors inside the TV numbers 2662, 2663 and 2664 - If you unscrew the back panel of the tv you will see the capacitors towards the top of the tv, from memory around the middle.
Replace the capacitors (make sure you get the polarity the right way round) and you should find all is ok.
Philips plasma won't turn on first time
I have found this on a site and am in the proccess of trying to mend my plasma PF9964 as it started to take longer and longer until it stopped coming on. I've got the back off so I just need to un solder capacitors and replace.
Here's the info I found.
Bad power switch circuit
General Comments
If you have this problem with your Philips 32PF9964: When I switch the TV on, it appears as though it is going to start i.e the green light comes on, then after about 10 seconds it switches itself off and the standby light flashes red. It takes 10 /12 times before it starts and is getting worse.
This is the solution:
The problem is three caps.
Change the cap 2663, 2664 both 100µ/25V
and 2662,1000µ/25V. After you have changed them your TV will work again.
You will find them easy if you unscrew the back on the plasma TV.
Cheers, Mike
Hi, after turning on TV
Your power supply board is dead, u know basic electronics’ and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Hope this help....
Tv cloudy and faces are red
TV needs CRT coolant replaced, once this is done the focus and color level of each CRT needs to be adjusted for optimum picture. expect to pay around $300 good luck, Julio at Millenium TV , Las Vegas NV (702) 736-1091
[email protected]
Lead from receiverbox 9965 to tv
I have a philips E box w/ pixel plus. my tv died. i paid over $400 for the flat tv receiver FTR 9965. send me an email and i will gladly sell for $100.
[email protected] 813-477-4517 i have just placed it on craigslist in Tampa, FL
Rick
