20 Most Recent
Philips 32PW6006 32" TV Questions & Answers
Red screen
Check and replace damaged component/s at the red output section circuit.
Power light not on, no
The whistling is caused by the power source that is overstressed by a short - a big part inside it has failed. The tv must be opened and the parts tested by a pro. Call one, there's nothing else you can do.
Television reverting to standby
Hi Phil.
Try adjusting A1 on loptx it is very critical & can cause the symptoms you are describing.
You could be right in saying the crt, Philips tubes are notorius for failing.
Im hoping your a tv tech if you are not DO Not do what I have written below tapping neck to hard can cause seriouse injury to your self.
Run set & tap the glass neck of crt if pic flickers or you see red blue or green flashing while tapping tube neck it will be the tube.
Let me know results there are a few things that can be done.
Chris..
Philips 28pw6615/5 tv
Got it now tried it on my own 28PW6615. With the remote pointing at the TV there are five coloured buttons on the top row. Immediately below these buttons are three buttons. The button on the left has what looks like a clock on it. The button on the right looks like a vertical double headed arrow with a horizontal line between them. If you press the left button together with the right button you will go to the "Installation" menu from where you can RF tune your TV.
PHILIPS PW8751/12
hi there, red light flashes means a shorted electronics componets is needed to be replaced. check for horizontal section prob. it maybe a flyback transformer, a transistor or diode. do some test. ty
PHILIPS 32PW9525
I didn't understand that your assistance was NOT free. So, if I had to spend some money for it and get some good advices, I think it would be better for me to take my TV set "phisically" to a customer service in the area where I live...Anyway thank you, but at this point I prefer to do by myself...
TV repair
hi there, yes it is worth fixing for a 32 inch tv. , check up the connection inside and some loose connection or some cold solder. do some cleaning and check up. ty
Wont turn on...
as it has came right by your cousin.
it means your set is ok no problem with it.
problem in remote only.
1 check battary contact & battary weak.
2 foreign particals deposited on contact or loose or broken print.
3 remote defective.replce it.
Error codes
same CRT problem have a look at a more detailed post on this forum
Turning itself off and snowy picture
problem is build up on the cathodes and when the reach maximum temperature they cause a short between heater and cathodes .also possible g2 and cathodes short circuit.One way is to separate the heater circuit H1,H2 and use a transformer or build a coil on the line output transformer (3 times not shore read up for it) and u will get 6v for the heater.Read this http://www.penders.cwc.net/otcolour.html it will help even if is for other problems. Good luck
TV won't come on and can hear a contstant clicking in the back.
Cheer UP!!! Its not that bad Im sure? Ok first off theres nothing in that set thats called a transponder, so dont let anybody work on your set thats not a technician. They can be hurt or killed. Your problem could be a simple cold solder connection on the sweep board but the longer you wait with these types of repairs the worse they get as they cause parts to go bad in the power supply, as it sresses them badly. Call an authorized servicer and ask for an estimate, and if you like the set and the cost is reasonable go for it, and maybe get it back before the cup games are on??!! Good Luck
