20 Most Recent
Philips 28PW6305 28" TV Questions & Answers
Controls not working on tv
Just do a hard reset, or a system reset to this TV. To make it a hard reset, unplug it from AC power socket, and re-plug it back after 20 minutes or so. This will make it a hard reset. To make it a system reset [factory reset], you have to enter its service mode option. Even though it can be done externally using the remote control, the procedure is somewhat semi skilled one; so will be better to contact any service technician. If you wish to get some details, check the site linked here. Surf the site in "
MOSAIC" view. It will make surf easy. Surf the site with patience.
I have accidentally turned the child lock on and
Get a Magnavox (or Philips, same company) brand universal remote and try this. I found this info at a tech website, but I haven't tried it myself
(never have used parental lock on any set), so I don't know if really a solution.
Philips sets use 0711
as the override code to defeat parent lock.
You may need to enter the code twice if it says "invalid code" the first
time.
Using the remote control:
Press the MENU key.
Scroll up or down until you reach AUTOLOCK or SMARTLOCK. Press the
"right arrow" key.
Enter code 0711. Enter it again if it says invalid code.
Once in
the AUTOLOCK or SMARTLOCK menu:
Scroll to BLOCK. Press the
"right
arrow" key. Scroll to BLOCKING OPTIONS. Press the "right arrow" key.
Scroll
to MASTER DISABLE. Press the "right arrow" key. This should unlock the
parental control.
Hope this works for you. Thanks for using
Fixya!
Philips 28pw6305 tv turns off
Hi.
If you are ok using soldering iron then try this.
REPLACE C2962 1000UF IN POWER SUPPLY FOUND TO BE LOW CAPACITANCE CAUSING RIPPLE ON 3.3V LINE AND CONSTANTLY RESETTING THE CPU.
Chris. http://dysonmanuals.inc.io/
Channels Switch by themselves?
I would examine the pushbuttons at the front of the PC board to see if they have been contaminated with any kind of liquid that was sprayed or spilled inside. If they are contaminated then you can try cleaning them with lacquer thinner or replacing them and cleaning the board. If they are clean then this is a symptom of a defective main computer IC, and I have seen this on many of these sets. Unfortunately, this IC is surface mounted on a sub board and the board would have to be replaced and reprogrammed, and this would have to be done by someone with experience in these sets.
I have Philips TV mode
I'm assuming that you have checked that the sound is not muted. To confirm that a reset to factory settings is the next procedure: Menu - Setup - General - Factory settings. If you don't see/hear any modifications then it's a hardware defect, not something with the settings.
This happens when the tv thinks that the headphones are used. Simple test to confirm that: plug in a pair of speakers and see if you get the sound on them. If you get and the situation doesn't changes when you unplug them then this is a mechanical defect: the small switch inside the headphone jack is faulty and keeps signaling that the headphones are plugged in when they are not.
The only way to fix that is to replace the jack, which involves a very delicate soldering procedure , one that only a good repairman can do - you must call one.
12/13/2023 4:44:25 PM •
Philips...
Answered
on Dec 13, 2023
Philips DVP3150V/37 DVD VHS combo Player. I am Looking for a universal control for Philips DVP3150V/37. Which one will work.
https://www.fixya.com/support/r29872378-universal_remotes_no_facsimile_remote
How many would you like?
Genuine PHILIPS NA725UD DVD VCR COMBO Remote ...
eBay
https://www.ebay.ca > ... > Remote Controls
Genuine PHILIPS NA725UD DVD VCR COMBO Remote DVP3150V/37 ; Quantity. 4 sold. 8 available ; Item Number. 143886913897 ; Compatible Brand. For Philips ; Accurate ...
$67.67 · In stock
PHILIPS 996500027557 DVP3150V37, DVP3150V, ...
eBay
PHILIPS 996500027557 DVP3150V37, DVP3150V, DVP3150 REMOTE CONTROL ; Model. DVP3150V ; Type. Remote Control ; Accurate description. 5.0 ; Reasonable shipping cost.
US$59.95
Buy PHILIPS NA725UD -996500027557 DVD/VCR Combo ...
ReplacementRemotes.com
https://www.replacementremotes.com > philips > buy-...
PHILIPS NA725UD-996500027557 dvd/vcr remote control for DVP3050V, DVP3050V/37, DVP3050V/37B, DVP3050V37, DVP3050V37/VCR, DVP3050V37B, DVP3150V, DVP3150V/37
12/5/2023 4:44:13 AM •
Philips...
Answered
on Dec 05, 2023
My rmt-d197a remote, i am trying to pair with my Philips t v
In order to pair your RMT-D197A remote to your Philips TV, follow these steps: 1. Power on the TV with the remote. 2. Press and hold the Setup button on the remote until the red LED light blinks twice. 3. Input the four-digit code that corresponds to your brand of TV on the remote. This should be found on the enclosed code list. 4. Release the Setup button. If the code is correct, the red LED light will blink twice. 5. Aim the remote at the TV and press the Volume Up button. If the TV responds, the remote is paired correctly.
10/31/2023 4:44:00 PM •
Philips...
Answered
on Oct 31, 2023
